1996 Dodge Caravan Sport Electrical Problems
jacomo
12-12-2005, 09:21 PM
Right rear directional, flasher and brake lights do not work. Drivers side are working fine. Putting new bulbs in didn't fix the problem. Any ideas as to how I can fix this annoying problem???? HELP!!!
B33p3r
12-12-2005, 09:48 PM
Check the ground wire. those sockets more than likely share the same ground.
HeadlessHorseman
12-14-2005, 06:07 AM
Check the red 10AMP mini-blade fuses to the rear lights in the fuse block under the dash and to the right of the steering column... there is one fuse for each side.
vipergg
12-15-2005, 10:58 PM
Try pulling the IOD fuse under the hood in the power dist. center for 60 seconds then reinsert . Even the brake lights run thru the bcm , may not help but it might and its easy to try . The bcm can cause all sorts of weird problems , lots of the internal and external functions run thru this thing.
