Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 12-12-2005, 04:42 PM   #1
trifit1
trifit1 Normal reputation
intermittent stalling when cold,code 11
My daughters 95 SOHC ATX has begun to die out during first 5 min of startup but only sometimes, it may or may not start up right away. After it is warmed up the problem vanishes and it runs great, when the thing dies I get a code 11. the cam and crank sensors have recently ben replaced. I have suspicions that the splice may be to blame on the cam sensor plug but why only when cold??
trifit1 is offline   Reply With Quote
Old 12-12-2005, 05:07 PM   #2
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: intermittent stalling when cold,code 11
Code 11 = No signal detected from crankshaft position sensor.
Code 11 = Intermittent loss of camshaft position sensor signal.
Code 11 = Intermittent loss of crankshaft position sensor signal.
Code 11 = Timing belt skipped one or more teeth.
You need to get the P code to identify which one you have. You may need to make sure the cam and/or crank sensors are seated correctly. If your timing belt skipped a tooth, you could be in big trouble. Do not drive it anywhere, get a scanner and check for the P code. Some stores like Autozone will let you rent the scanner, for a deposit, then you get it back when you take the scanner back.
das2123 is offline   Reply With Quote
Old 12-12-2005, 06:27 PM   #3
trifit1
timing belt is right on, I am going to be sure of the cam and crank sensor connections and hopefully that will cure the problem 'Thanks
Bookmarks
Google
Web AF
