Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 12-10-2005, 12:57 AM   #1
juggalowraith
juggalowraith Normal reputation
95 neon starting troubles
I have a 95 neon. Since i bought the car i have to give it gas to start it. If i try starting it without gas it just turns and turns over. ONce i hit the gas pedal it starts right up. The only way it starts normal is if it sits overnight. Once i start it in the morning it starts right up without gas. But than the rest of the day you need to give it gas. I dont know if this problem is related to the starting problem. Two or three times now after i drive the car for a while it shuts off when you give it gas. It did that twice to me in the past couple of months. It didnt do it recently though. I checked the error codes and it only comes up 22. That is temperature coolant voltage too high or too low. I had changed the temperature coolant sensor, fuel filter, coil pack, throttle body, and plugs. I dont know what else too do. Please help
juggalowraith is offline   Reply With Quote
Old 12-10-2005, 10:42 AM   #2
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 95 neon starting troubles
Have you had your battery checked? Your fuel pump might be going out on you also.
das2123 is offline   Reply With Quote
Old 12-11-2005, 01:21 PM   #3
juggalowraith
It is a new battery. I also got a new alternator. Someone told me to try changing the map sensor? I dont know what to do? Is their a way to check the fuel pump?
Old 12-11-2005, 07:50 PM   #4
1thunder
1thunder Normal reputation
clean the throttle body bore really good and on the + battery post there is a smaller red wire it needs to be cleaned where it connects at the battery post stud and the addaptive memory must be reset after everything is done you can do this by disconnecting the pcm connector for about 15 minutes. If you try disconnecting the battery to try resetting memory
it may take up to 24 hours depending on options on car more options means more capacitors to discharge
1thunder is offline   Reply With Quote
Old 12-12-2005, 04:33 PM   #5
das2123
das2123's Avatar
Re: Re: 95 neon starting troubles
Originally Posted by 1thunder
If you try disconnecting the battery to try resetting memory it may take up to 24 hours depending on options on car more options means more capacitors to discharge
Only takes about 15 minutes on my car and it has every option available. A better/easier way to reset the PCM is to pull the fuel pump fuse for about 15 minutes.
Old 12-13-2005, 11:00 AM   #6
juggalowraith
i cleaned the wire and i reset the computer. It still didnt work. I dont know what to try next
Old 12-13-2005, 11:01 AM   #7
juggalowraith
I forget to add that the car starts right up after it is cooled down. Like i said it starts normal in the morning. But after you drive the car it wont start unless you let it sit for a couple hours. It seems like when it cools down it starts right up
Old 12-13-2005, 12:43 PM   #8
das2123
das2123's Avatar
Ok, do you have any error codes right now? It could also be a vacuum leak somewhere or a stuck EGR valve causing your slow starts.
Old 12-14-2005, 10:35 AM   #9
juggalowraith
How do you check the egr or vaccum hoses? The only error code im getting is 22. That is temperature coolant sensor voltage too high or too low. I changed the sensor two or three days ago but it did not erase the error code.
Old 12-14-2005, 12:27 PM   #10
das2123
das2123's Avatar
Re: Re: Re: 95 neon starting troubles
You have to erase the code by pulling the fuel pump fuse in the PDC or disconnecting the negative terminal on your battery.
To check your EGR valve, you will have to remove it and then see if it is working properly. Search EGR in this forum, I have told someone how to get the valve off before.
Checking for a vacuum leak, means you need to have the engine running and inspect/check all of your hoses for possible leaks.
Old 12-17-2005, 12:38 AM   #11
juggalowraith
i checked the egr and hoses and i cleared the memory
it still didnt fix the problem
Old 12-17-2005, 12:46 PM   #12
das2123
das2123's Avatar
I had changed the temperature coolant sensor.
It is possible the sensor you got is a bad one. It's not totally impossibe to get a "bad" part from the store. You problem sounds like an overheating issue still. Try getting a new senor, check to make sure you have the right mixture of coolant to water ratio, if that does not help you may have to put in a new radiator. Also a new thermostat might help.
Bookmarks
Google
Web AF
