Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Suzuki > Sidekick
Old 12-09-2005, 08:12 PM   #1
SnipesXxX
SnipesXxX Normal reputation
97 sidekick won't start
Just tried to start my 97 sidekick today and it won't start. It cranks but isn't fireing up. Any ideas?
For a while now it has been acting funny. Seems like if you didn't drive it for at least 30mins when you first started it that day it wouldn't start back without setting for a little while. Don't know if it needed to warm up or what. Sounds like something was acting up and has finally went out today?
Any suggestions?
SnipesXxX is offline   Reply With Quote
Old 12-13-2005, 03:27 PM   #2
dgee
dgee Normal reputation
Re: 97 sidekick won't start
when did you last tune it up.are you getting gas and spark.and check the ignition fuse.
dgee is offline   Reply With Quote
Old 12-18-2005, 07:19 PM   #3
ehime
ehime Normal reputation
just to throw in, you might want to check your battery
too, I've seen similar problems on other cars that ended
up stemming from a battery that can't take a full charge.
try turning off all electricals (radio, lights, dome, etc) and
see if that makes a difference. best luck to you!
ehime is offline   Reply With Quote
Old 12-28-2005, 04:54 AM   #4
SnipesXxX
Turned out to be the fuel pump
Old 01-01-2006, 07:35 PM   #5
dgee
was it the actual pump being no good or the wiring to the pump. because i had same problem but it was the wires on top of the tank.
Old 01-01-2006, 07:46 PM   #6
SnipesXxX
Re: Re: 97 sidekick won't start
I didn't put it in. My dad dropped the tank and I told him before giving $150 for a pump he needed to check to make sure the wire was giving 12v. He said it was and bought a pump and put it in and it started right up.
Bookmarks
Google
Web AF
