12-08-2005, 09:00 PM
ABS Box Hangs UP?
6 mts ago the wifes ABS light came on and the box runs when the car is shut off the only way to get it to quit is unhook it which i did cause it get so hot running hours at the time, i called dealer said that want under recall and said the new ABS box wsa gonna be $600 + labor i said no way and left the ABS box unhooked anyone have any ideas on how i might get another one? withough going thru honda?
12-08-2005, 09:17 PM
Isuzu Guy
Re: ABS Box Hangs UP?
www.car-parts.com
find a salvage yard near you.
12-08-2005, 11:51 PM
Hmmm.. I thought the ABS recall was the fix for the constant running ABS servo motor?!? I'd pull the ABS fuse and dash lamp before I dumped more than a couple hundred bucks into a rodeo ABS system.
Joel
2007 Chevy Cobalt LS 4dr, auto
2008 Honda Odyssey LX chick magnet
Gone but not forgotten  : 2001 Ford Windstar LX, 2005 Trailblazer LS 4x4, 2002 Isuzu Rodeo LS 4x4 & and many more.
12-09-2005, 08:26 PM
Hey man I will just tell me how i unplugged the abs box but the light on the dash still comes on how can i get the light to go off inside the car im not a proficient mechanic, but ill try, thanks
12-11-2005, 09:36 AM
Re: Re: ABS Box Hangs UP?
Dealer told me there was a recall but it wouldnt fix that problem so i didnt bother with it but
WHHHHHHHHHHHOOOOOOOOOOOOOOOOOOOOOO
I took my Haynes book and went to work on those christmas lights on the passport dash and i got everything out and took the ABS bulb, the check engine bulb, and the gas tank flashing bulb out cause all 3 were bright and burning
check engine was for an egr valve i cleaned the valve but it didnt do any good and i cant take the $150 price to replace it which wont guarantee that it will be fixed, ABS light was where i unhooked the constantly running ABS box, and the Fuel Light was where it needs a new sending unit so until i get the money to repair the unit i wont have to see that light for the next 6 mths.!
12-11-2005, 12:01 PM
Cool! You can call it the pre-Christmas, poor man's repair job! Keep in mind you may need a functioning CEL to pass state inspections. I know you need one on all 1996+ in NYS  . They cycle the ignition to verify proper functioning of the CEL.
Joel
12-11-2005, 06:15 PM
What is the CEL? Check Engine Light
SC hasnt had inspections in years so maybe ill be ok, the egr valve was what the autozone guy said was causing it but i cleaned the old one and it kept coming back on i was thinking if i put one on it doesnt the place where it bolts on to need to be cleaned out also? and if so how do you clean that part of the engine.
12-12-2005, 07:22 AM
Originally Posted by Whitaker 24
...the place where it bolts on to need to be cleaned out also? and if so how do you clean that part of the engine.
Try a search. It's all in here: http://isuzufaq.ibctech.ca/
Joel
12-13-2005, 06:55 PM
My 99 Isuzu Amigo/Rodeo V/6 4X4 did the exact same thing as yours! I took it to the dealer & they replaced the whole ABS box under a recall with NO COST TO ME WHATSOEVER!!! I would do more research if I were you! This is the same engine & body assembled at the same plant as your Honda and is having the same problem! Hope this helps!
Glen
(sonofsong)
P.S... I would be wary of your mechanic!!!
