heater doesnt work
supateggy
12-08-2005, 08:25 PM
ok to start off from the first. recently i have replaced my water pump, t- stat, a/c control switch. i have flushed out the whole coolant swstem including the heater core. however when switching from cold to hot their is no differance in air change( it doesnt get slower or faster hot or colder)
what do i do? what else i their to replace? please help me i am in desperate need of advice. i have a 6 month old and i need to get this problem resolved.
thanks for any advice
WVPurpleJimmygirl
12-09-2005, 12:59 PM
I have the same problem, i think these cars are junk by the looks of it. Good luck finding an answer. I have no 4 wheel drive and no heat.
halle
12-15-2005, 12:44 PM
make sure the coolant mix is at least 50/50. hope that helps
goser
12-18-2005, 02:17 PM
No leaks I guess, right? My first clue that my water pump was going was a lack of heat...then the gallon of antifreeze on the ground--make sure your fluid is topped right up.
Good luck
JDJ
01-05-2006, 01:29 PM
I am currently elbows-deep in my coolant system, searching for the same culprit you are. However, in addition to my heater core not working, I have to hold my breath every time I must restart the engine after driving short distances! Has anyone had a similar problem and resolved it themselves?
ChrisGood
01-05-2006, 05:46 PM
When I had no heat it was due to a bunch of sludge in my coolant system, took about 5 rounds of highpressure to make it come out as clean water, old neighborhood so water pressure is actually around 125psi (normal is 50 - 80).
In the case of all that maintenance, I would say your heatercore is still clogged... as long as the mixing door still works.
JDJ
01-06-2006, 12:38 PM
Hey thanks for the tip, at the end of the day I had the same problem, but just to be safe I went ahead and replaced the thermostat. Might as well, as long as I was in there.
