Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-05-2005, 07:23 PM   #1
coyote379
coyote379 Normal reputation
Question 94 Z34 engine swap
Any body know if a 4.3 will fit into a 94 Z34? Will I need to swap transmissions too? Its time to pull the old 3.4 out.
coyote379 is offline   Reply With Quote
Old 12-05-2005, 09:35 PM   #2
Schurkey
Schurkey Normal reputation
Re: 94 Z34 engine swap
Chevy small block variant 4.3???
Good luck. Bellhousing bolt pattern isn't even close to correct, and it'd weigh a ton more. Overall much larger than a 3.1, although I don't know if it's taller/wider than a 3.4. Probably longer, although, again, I'm not sure. If you could get it to bolt in, the extra torque would kill the trans in short order.
You'd be custom-making the exhaust system, too.
Declared "the flat out DUMBEST poster on this board" and have earned the moderator-sanctioned rating of "dumbass". And mighty proud of it.
Schurkey is offline   Reply With Quote
Old 12-06-2005, 08:26 PM   #3
coyote379
4.3 v6. I know it wouldn't bolt up to anything.Also know the trans from the 3.4 would not work. Just wanting to know how much cutting and front end mods it would take. I was also thinking about rear wheeel drive.I know lots of work and mods to everything under the car.Has anybody ever done this to a Lumina?
Old 12-07-2005, 08:44 PM   #4
corning_d3
corning_d3 Normal reputation
Send a message via Yahoo to corning_d3
I've heard of someone that was going to try this on a Monte Carlo, but i never heard from him again.
corning_d3 is offline   Reply With Quote
Old 02-02-2006, 08:50 PM   #5
coyote379
How about putting a NorthStar front clip in a Chevy Lumina Z34, has anyone heard of doing that, and if so what magazine was it in?
Old 02-03-2006, 03:40 PM   #6
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
All these mods are way more expensive than the gains would justify. There is no point. If you want a RWD car, buy a Caprice/Impala or Camaro. It would cost WAY less, and you could re-sell it without taking a huge hit. My estimation for parts/labor/fabrication would be $1500-$3000 just for parts and 100's of hours of labor. Again, NO POINT.
Would you drive any better with that cell phone up your ...?!
richtazz is online now   Reply With Quote
Old 02-04-2006, 10:53 AM   #7
coyote379
I don't want a rwd car.I want to swap out that 3.4 for something alot better.I've talked to a shop that has swaped a complete mid 90s clip from a Cadallic with a Northstar V8,trans and transaxle into a Z34 with not alot of mods to the Lumina. Both clips bolt up to the same bolt pattern,even the ecm is an easy swap. GM to GM. The biggest cost of the swap would be the Cad front clip. I wonder would it be called a Luminallic?
Old 02-08-2006, 06:49 PM   #8
sLoW'n'StEaDy
sLoW'n'StEaDy Normal reputation
Send a message via AIM to sLoW'n'StEaDy
did you pull you 3.4L?
jus wondering cuz im lookin for a few parts.
exhaust X-over pipe, valve cover, cam housings
sLoW'n'StEaDy is offline   Reply With Quote
Bookmarks
Google
Web AF
