Re: 1995 Chevy Lumina Newly Rebuilt and won't stay running, THEFTLOCK problem?
The radio will not cause the engine to die. The antitheft system won't either. First of all, i hope you primed the oil pump before starting, or at least applied cam prelube to the rod, main, thrust, and cam bearings. Secondly, check the oil pressure by installing a guage in the place of the oil pressure sending switch, located above the starter. If there is no oil pressure, the engine will not stay running because the oil sending switch controls the fuel pump. Check these, then post back results..
