Originally Posted by jugstah
nothing... none of them work anymore... all died one by one gradually...
Troubleshooting or replacing the blower motor resistor or fan is not that difficult. High probability it is the resistor. But to be sure it's always a good idea to bench test the blower motor by jumping 12 volts to it just to make sure if its OK. If blower turns its probably a resistor.
Here's a pic with the blower motor removed and to the back is the resistor. This is applicable only if you have a manual control HVAC system and not the digital climate control.
There are 3 bolts that hold the blower motor up to the housing. Good luck!
