Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 12-04-2005, 09:46 PM   #1
Xx ReasoN xX
Xx ReasoN xX's Avatar
Xx ReasoN xX Normal reputation
Send a message via AIM to Xx ReasoN xX
Igniton Problem
ok i replaced my starter in the summer than the igniton switch about a month ago because it was not working properly but now when i turn on my car the starter turns the motor over but it turns off like in one sec, and throletting it dosent help either it takes me like at least 10 tries to turn it on. Please let me know if you have any idea of how to fix this problem.
Xx ReasoN xX is offline   Reply With Quote
Old 12-06-2005, 06:33 PM   #2
rruddfan21
rruddfan21 Normal reputation
first, check and see if the plugs are getting spark. if they are, check and see if the injectors are firing fuel. if they are, then you may have a compression problem.
rruddfan21 is offline   Reply With Quote
Old 12-11-2005, 03:56 PM   #3
katherine1
katherine1 Normal reputation
Re: Igniton Problem
i have a 96 cavalier it will not turn over we replace the ignition module that wasn't the problem what could it be please help
katherine1 is offline   Reply With Quote
Old 01-01-2006, 11:15 PM   #4
ARCAutomotive
ARCAutomotive Normal reputation
Re: Re: Igniton Problem
Kathrine1, You state "it does not turn over". The ign module does not control the motor turning over, the starter does. Does you car have a automatic or manual transmission? Does it turn over but not start (fire)?
Rruddman, what you described was a starter drive that kicks out from the flywheel prior to the engine firing. You turn it over, it cranks for a few turns and stops cranking, is that what is happening? if it is, its a starter issue.
ARCAutomotive is offline   Reply With Quote
Bookmarks
Google
Web AF
