'01 Rodeo V6 gas guage acting funny
weathermedic
12-04-2005, 02:50 PM
Parked the car overnight with needle reading just over a quarter tank. Got in the next morning, started up and the orange low fuel light came on and needle was reading E. I did park on a SLIGHT rearward incline, but I always do (it's my driveway) and this has not happened before. I started driving and the needle went back up to just over a quarter tank.
When I filled it up, it only took 8.6 gallons. The tank holds 20. I know that E gives you some reserve (usually a couple of gallons) but I find it hard to believe my tank had 11+ gallons in it and the guage was still reading just over a quarter.
Any ideas, or other users with similar problem?
Jason in NYC
rodeo02
12-04-2005, 03:21 PM
All too common for the 1998+ rodeo :disappoin . Try a search for "gas gauge" or "Sending unit".
G/luck
Joel
Westsacramento
12-04-2005, 10:32 PM
i am having the same problem with my 2001 rodeo. I was thinking about selling it or trading it in but need a SUV type vehicle. Any Recommendation
amigo-2k
12-04-2005, 11:37 PM
http://isuzufaq.ibctech.ca/#faq2
if you are the orginal ower it is a free fix at isuzu.
Westsacramento
12-05-2005, 02:39 PM
I am not the original owner. I am the second owner and only have 58,000 on the vehicle. I just took the vehicle in today and the shop stated that it may be covered under warranty they will get back to me.
If I am the subsequent owner is there a standard warranty policy on the 2001 Isuzu Rodeo. I know for previous years I have seen 5yr/60,000 for subsequent owners but nothing in writing on the 2001 Isuzu Rodeo.
I also had a problem with the Transmission leaking which this dealership took care of under warranty about 9 months ago. The explaination was vague when I spoke with them but they stated it happens all the time.
Thank you
rodeo02
12-05-2005, 03:23 PM
....I know for previous years I have seen 5yr/60,000 for subsequent owners but nothing in writing on the 2001 Isuzu Rodeo.
The only thing you will find on isuzu.com is this: http://www.isuzu.com/owners_warranty_10120k.html Second owners does default to 5/60 for p-train warranty. You can verify it by calling the 800#. The fuel pump is covered by p-train warranty and the sending unit and fuel pump are considered one part to isuzu. A new sending unit will fix your gas gauge for another ~50Kmi.
G/luck
Joel
amigo-2k
http://isuzufaq.ibctech.ca/#faq57
your tranny leak was most likely the above.
Westsacramento
12-05-2005, 03:37 PM
G/luck
Joel
THANK YOU
Westsacramento
12-05-2005, 03:41 PM
Thank you that was the problem I do believe.
Is there anything else I should worry about after I get this Fuel Censor Fixed? Reason is that this vehicle is my Wife and we have a new baby on the way. The last thing I want is for the car to be a unreliable.
Also the New Sensor is only good for 50,000 miles?
it is a 4x4 2001 Rodeo S.
rodeo02
12-05-2005, 03:46 PM
...Also the New Sensor is only good for 50,000 miles?
That's *about* how long the sending units are known to last. The contacts wear out on them causing the funky gauge readings. Not a huge deal. Just reset your trip odo & fill up every 250-300 miles should your gauge crap out.
Joel
Westsacramento
12-05-2005, 09:30 PM
Joel
Okay I got a call from the Dealership and he said it was covered under the warranty. Also He stated that because it is just the warranty they are going to replace the fuel pump as well. The Dealership basically gave me no hassle and were great. Thanks so much
rodeo02
12-05-2005, 09:40 PM
You've got a good dealership if they are willing to warranty the gas gauge issue w/ out a run-a-round. Most will put up a huge stink on that one.
Joel
Joihan777
12-06-2005, 02:42 PM
Hi Westsacramento,
I'm in Elk Grove, what dealership treated you that nice?
I'll be selling my Rodeo Sport (a must...too many babies)
and I want to get some warranty work done before people
come to the door.
Thanks, johann
Westsacramento
12-06-2005, 04:23 PM
Hi Westsacramento,
come to the door.
Thanks, johann
Johann,
It was Great Valley Isuzu Madza Jeep. They are on Fulton south of El Camino. The passed two times I went in there they knew exactly want was wrong and already have the warranty information. I spoke with a Jay and he was great.
Hope that helps.
Elvis
weathermedic
12-19-2005, 10:35 PM
Went to the dealer and told them what the problem would most likely be. Manager said that if it's just the fuel sending unit, it would not be covered under the 10yr/120k warranty. I informed him to double check with Isuzu corporate about that. I also told him to ask them if they recommended to change the entire fuel pump.
He got back to me and said (to my surprise) that Isuzu recommended to change out the entire fuel pump which is covered under the warranty. He had to order it and the next available appointment was after New Year's! They are also a Lincoln-Mercury service center, so they are always busy with those vehicles (lots of Navigators always in the garage when I go, wonder why?)
Anyway, I am just glad they will replace the entire unit for me under the warranty.
Jason in NYC
Tom01Rodeo
12-20-2005, 05:57 AM
I've got the same problem with the gas guage. I'm out of the factory warrany but have an extended warranty w/$100 deductable. I usually try to do most work myself and was wondering if parts would cost over $100, I'd have a shop do this. Any suggestions? In other words, I wonder if they'd try to repair only the sender or would they need to change out the entire fuel pump ass'y?
weathermedic
12-20-2005, 09:26 PM
You can replace just the sending unit (I think the price for that is around $40) if you want. Price for the entire fuel pump is about $250 I think.
They recommend to change the entire fuel pump becuase I'm sure it doesn't lag too far (timewise) behind the sending unit in going bad.
Jason in NYC
Tom01Rodeo
12-20-2005, 11:00 PM
Jason in NYC
Looking at the Isuzu FAQ's, seems the sending unit only isn't an option for my '01 model. It may not even be available, only the entire fuel pump ass'y.
rodeo02
12-21-2005, 11:20 AM
If you've got a shop that will work with your AM warranty, $100 would be a bargain to have the fuel pump and sending unit assembly changed out. The FSU/pump assembly itself is like $300+, labor would probably be a few hundred on top of that.
Joel
Tom01Rodeo
12-31-2005, 12:17 PM
Joel
Ok, I got it fixed yesterday. They replaced the entire fuel pump ass'y. Total cost was $527 and my part was the $100 deductible. So far, the extended warranty has paid off for this vehicle and I still have 2 years left! Last year the AC went out, cost $1200 to fix!!
When I took it in for service, I also complained about an ongoing acceleration problem that seems to be getting worse. On the on-ramp the other day, I was about 3/4 throttle and the RPMs were climbing normally until about 4K, then there was a dip in the RPMs then it picked back up. Its always had an acceleration problem since I've owned it.
Fuel pump must've been getting weak, as the new one seems to have solved the problem!!
BTW- the dealership said they keep 3-4 fuel pumps on hand since its so common :shakehead:
rodeo02
12-31-2005, 01:32 PM
You can't beat that deal on the FP/FSU!
.. On the on-ramp the other day, I was about 3/4 throttle and the RPMs were climbing normally until about 4K, then there was a dip in the RPMs then it picked back up. Its always had an acceleration problem since I've owned it.
My 2002 has done that since new as well, If I wind it out at WOT, the RPM's waver a bit almost feeling like the tranny is slipping. I dunno if it's the variable runner intake switching, the throttle by wire or the ion sensing stuff :uhoh: . Either way, it runs/shifts like a top, just does that weird stuff if I mat it.
Joel
Tom01Rodeo
12-31-2005, 03:29 PM
Joel
I was in the same boat. Did the egr cleaning, replaced plugs, IMG replacement trying to fix without taking it in. I was sure happy when it turned out to be the FP ass'y and I didn't have to pay a separate deductible! When I took the Rodeo in, the service writer suggested it may be the fuel pump and his tech would replace the ass'y before trying to diagnose the acceleration problem. He took it out for a spin afterwards and said he didn't sense any trouble. I was sceptical and told them I'd return quickly if it wasn't fixed. Didn't need to!
Not sure how you'd troubleshoot a fuel supply problem. Do their scan tools report fuel pressure? There would have to be some sort of fuel pressure transducer in the fuel system for the processor to know what the pressure is.
joewildlife2001
01-03-2006, 11:07 AM
WHEW!
My 2001 is doing the same thing.
The dealer told me I couldn't buy just a sending unit, have to replace the whole pump assembly.
I'm the second owner and have 59,700 miles on it!!!!
I'm calling a dealer TODAY!
thanks!
Joe
chriswatt
03-30-2006, 12:05 PM
My dealer says it is just the sending unit so it is not covered under warrenty. I also have a 2001 rodeo LS
joewildlife2001
03-30-2006, 01:52 PM
Find another dealer!!!!!
The fuel sending unit is NOT a part that can be ordered or gotten separately. It is PART of the fuel pump. The fuel pump is covered under warranty, and comes WITH the sending unit assemply. The Assembly is defective if PART of the assembly is defective, no matter which part.
I had this part replaced under warranty at an Isuzu dealer in St. Louis. They even had Isuzu roadside assistance pick up my Rodeo on a flatbed and bring it to the dealer, some 150 miles, to make sure the warranty did not expire before it got to the dealer, as I was cutting it close.
I think it was Webster Groves Isuzu that did the work. Another dealer, St. Charles I think, was also going to do the work under warranty, but since Webster Groves was closer that is where it had to be hauled by the free roadside service.
So, I got two dealers who disagree with yours!
Get a dealer to replace the whole fuel pump assembly for you. Mine was and the problem is fixed.
Joe
chriswatt
03-30-2006, 04:05 PM
I am in PA and tried 2. When I had the corporate call though they said it was the level sensor and not the fuel sending unit. Where in the level sensor?
Thanks
Gizmo42
03-30-2006, 08:39 PM
The level sensor IS the fuel sending unit. It IS a seperate part from the fuel pump and can be bought and replaced seperatly ($30-35 from st. charles) though it attaches to the fuel pump. However, it IS covered under warrenty. There are plenty of ppl on this and other boards that had them replaced by dealers under warrenty. Some had to go through the customer service line and get them to convince the dealer though.
joewildlife2001
03-30-2006, 10:36 PM
Nope Gizmo, you are wrong on that one.
The fuel sending unit is NOT available as a part by itself. IF it is bad, you must replace the whole fuel pump assembly.
You have a 99 and that may not be the case with yours but it did change with the 2001. I spoke with St. Charles Isuzu myself and that dealership was going to do the work under warranty BECAUSE the sending unit IS part of the fuel pump (assembly) and the (assembly) was malfunctioning.
Chris, the level sensor is the sending unit and it is part of and attached to the fuel pump assembly. Explain this to your dealer's and see if they change their tune. Tell them you want them to replace your fuel sending unit. They will say, sorry, they have to replace the fuel pump assembly. Then explain that the fuel pump (assembly) is covered by the powertrain warranty and rock on!
Joe
amigo-2k
03-30-2006, 11:10 PM
http://www.planetisuzoo.com/articles.htm/116
I think joe is right about the +2000 having an intergrated sending unit. And yes it is covered by the powertrain warranty since it is part of the fuel system.
This is from the Isuzu website (I some folks have printed this off and showed it to the dealer to inform them that the fuel pump is covered).
Isuzu's 10-Year/120,000-Mile Powertrain Limited Warranty
for 2000-2002 model-year vehicles excludes commercial or fleet vehicles. The Powertrain Limited Warranty is transferable to immediate family members only. See your Isuzu dealer for warranty details.
What is covered:
Engine
Cylinder head, block and internal parts
Valve cover
Oil pan
Valvetrain
Timing gears, chain or belt and cover
Oil pump and cooler
Water pump
Fuel pump
Flywheel
Engine mounts
Gasoline fuel injection equipment
Seals and gaskets
Transmission and Transaxle
Case and all internal parts
Torque converter
Transmission and Transaxle mounts
Seals and gaskets
Steering
Steering gear housing and internal parts
Steering column assembly
Power steering pump, hydraulic cylinder and hoses
Seals and gaskets
Suspension and Axle
Front upper and lower control arms
Knuckle spindles, hub and hub bearings
Front/Rear differential and internal parts
Axle shafts and constant velocity joints
Seals and gaskets
Propeller shaft
Torsion bars
Ball joints
Stabilizer bars
For more information on any of the Isuzu Protection Plans, contact your Isuzu dealer or call 800-343-0305.
chriswatt
03-31-2006, 07:12 AM
Thanks Joe and others. I went to the parts dept and they do sell the sending unit by it self. It comes with 2 but you only use one. I talked to 2 different people at the Isuzu customer service and neither one would convince the dealer since they said it was separate part. I tried another dealer over the phone and same thing. they said not covered. I guess I will have to fix myself.
joewildlife2001
03-31-2006, 09:18 AM
Chris,
I just went through this a few months ago. perhaps Isuzu started making the sending unit available, but it was NOT available as a second component for the 2001, as recent as a few months ago.
that said, I would say don't block out a whole weekend to fix the thing until you have the actual part in hand. I'm still not convinced.
good luck,
Joe
ps I sold my Isuzu for a Tundra that could pull my boat. I think my Rodeo also had a bad fuel pressure regulator...very uneven acceleration, even after the new fuel pump
Shore_Fisher
11-09-2010, 10:56 AM
Anyone give me the current optimum supplier for a fuel level sensor? Rock Auto does not appear to carry one.
Also, any thoughts on changing the fuel pump at the same time? I am inclined to NOT change it, as it seems pretty easy to drop the tank on this vehicle.
156k 01 V6 Rodeo
amigo-2k
11-09-2010, 11:48 AM
You have to pull the whole pump to get to the sending unit. If you have 156k on the original pump it might be worth swaping out the whole unit...
Shore_Fisher
11-11-2010, 02:37 PM
I read from the new pump manufacturer that they recommend either a tank pressure wash or a new tank (!) when the fuel pump is replaced. What is the general consensus on needing to do this? Sounds good, but if they mention a new tank I am thinking it may be a difficult job (Baffles, etc).
johnboy583
02-18-2011, 02:00 AM
You can get a new sending unit for your tank here...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180322482694&viewitem=&sspagename=STRK%3AMEWAX%3AIT
In the forum there is a page about how to install... about 2 hrs with simple tools.
