02 Si keyless entry problemssivic02 12-03-2005, 10:16 PM ARRRRRRGGGHHHHH!!! Ok, since thats out of the way. My keyless entry wont lock or unlock the drivers side door or set the alarm. It works for the passengers and the hatch lock just fine but the problem with that is that I usually try to enter and exit my car through the drivers door. The lock still works just fine when I use the key or the lock/unlock button inside the car. Im at a loss, help meeeeeeeee! BrodyP 12-04-2005, 12:26 PM Freakin noobs :icon16: I dunno I did some searhing came up empty handed..Its odd that it works inside but the buton wont trip it...You already proved the actuator works..Perhapse an electrical problem..Let us know the outcome I'll do some more investigating. GScivic7 12-04-2005, 01:14 PM If it's still under warranty take your car in. If it's not, it sounds like you have a problem with the brain. The transmitter itself seems to be working fine. Do the 02s use the factory headunit as the brain like the 6th gens? You could try just replacing the factory headunit and reprogramming your remote. Automotive Network, Inc., Copyright ©2012
