91 Lumina HELPNEEDS HELP 12-03-2005, 04:50 PM I need help I have a 91 lumina and the spark plugs dont have any current to them. I dont know what this is I changed the cables to the battery and this just happend overnight. Help as soon as possible please! maxwedge 12-03-2005, 07:53 PM This cAn be a complicated diagnosis, do you have injector pulse? A noid lite should be used to check this. If you are unfamiliar with this type of repair, you should get expert on site help here. jeffcoslacker 12-03-2005, 09:46 PM Any arcing when you were changing the battery? It hasn't started since, correct? jeffcoslacker 12-03-2005, 09:48 PM Check all your fuses to begin with. I've had GM cars towed into the shop after jumpstarts went wrong with ECM, Crank sensor, FI, A/C, and other fuses blown from arcing or reverse polarity. NEEDS HELP 12-04-2005, 02:38 AM Ok I will check all fuses Automotive Network, Inc., Copyright ©2012
