Is my Water Pump bad?
auxbar
12-03-2005, 04:42 PM
1994 GTP 3.4L 114K I am running without a thermostat right now, because if I put one it, my car overheats. Without the thermostat, I am fine, except for the fact that the car will not get above 150 degrees and its getting pretty cold outside. When I remove the radiator cap, and start the vehicle, it does not appear that the coolant is circulating. It just kind of sits there. If anything, it spills over the top a little. If I goose the throttle, nothing changes. Its as if the water pump is not really pumping. Does anybody know of a test I can perform to confirm the functionality of my water pump?
GTP Dad
12-03-2005, 06:38 PM
If the water pump were not pumping at all the car would overheat regardless. I would assume that there is some movement in the coolant but if it overheats with a thermostat I would have to believe that the water pump is indeed bad.
Ripn12s
12-03-2005, 08:53 PM
take off the hose and start the car. if water starts pouring out then the pump is working
richtazz
12-05-2005, 04:59 PM
I'd check the radiator to see if it's blocked.
