Programming 2002 Grand Prix Keyless remotes
srhopkins
12-02-2005, 06:12 PM
Can anyone tell me how to do it. Thanks.
Ridenour
12-02-2005, 09:21 PM
It should be in your owner's manual, but I'm going to move this to the Grand Prix forum - you'll get more answers.
srhopkins
12-03-2005, 03:12 PM
Book says see dealer for programming remotes.
BNaylor
12-03-2005, 08:53 PM
Try the procedure below. If this doesn't work then you may have to go through a GM dealer. Good luck!
Document ID # 681936
2002 Pontiac Grand Prix
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock transmitter (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System.
Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
Repeat the previous step in order to program each additional transmitter.
Install the MALL PGM fuse into the fuse block.
Operate the functions of each transmitter in order to verify correct system operation.
© Copyright General Motors Corporation. All Rights Reserved.
srhopkins
12-04-2005, 11:35 AM
It worked great thank you.
Important
Important
Niq
12-04-2005, 12:30 PM
What was the name of the reference material you dug that out of? I think I gotta get me a copy... 8)
BNaylor
12-04-2005, 12:54 PM
It's from the GM service manual which covers RKE. Beats the Haynes and Chiltons hands down. Expensive but worth it if you plan on keeping your car for awhile or like to do a lot of DIY work.
Niq
12-04-2005, 02:02 PM
Cool, thanks! I hope your talking about the 2002 Grand Prix Service Manual from Helm Inc. I have it on order now.... I get it Wednesday.
Onblsht
12-04-2005, 06:52 PM
Yup, I had a copy of the same instructions when I ordered my remotes. Good post.
