Faq thread suggestions.
Pages : [1] 2
Shortbus
12-02-2005, 05:56 PM
If any of you have or know of a faq thread that needs to be added to the blazer faq and how to section just post it up here and I will get it added to the new thread.
Please post a link to it and I would prefer that it does not link to another website. But if it is a really good faq or how to and it links to another website I will consider putting it up anyway.
John
93LT
12-02-2005, 06:44 PM
How about adding this thread as a link?
.3 CPI Injector replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=473110&highlight=4.3+CPI)
blazee
12-02-2005, 07:12 PM
Here's another door hinge pin and bushing how to, it's got a little more detail than the current one:
http://www.automotiveforums.com/vbulletin/showthread.php?t=476619
We see a lot of CPI problems here. Here's a thread with info about it:
http://www.automotiveforums.com/vbulletin/showthread.php?t=462726
Here's one with some great pics:
http://www.automotiveforums.com/vbulletin/showthread.php?t=473110 (http://www.automotiveforums.com/vbulletin/showthread.php?t=473110) <--- EDIT nevermind you posted that one while I was typing.
Cluster Mod how to:
Convert Your Cluster & Control lights to LED's How-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=379971)
Drum to Disc Brake how to:
Drum to Disc brake rear end swap how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=372515)
Heated seat how to:
Hot butt how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=366533)
Factory fog light switch with after market fog lights how to:
Factory fog lamp switch with non factory fog lamps. (http://www.automotiveforums.com/vbulletin/showthread.php?t=356665)
Info about common tranny problems:
Transmission Problems: Common Issues and Solutions (http://www.automotiveforums.com/vbulletin/showthread.php?t=461182)
Low speed ABS activation:
Read for Help **ABS Activation At Low Speeds** (http://www.automotiveforums.com/vbulletin/showthread.php?t=425516)
96+ Hard start, no start, rough idle info:
96+ Hard Start, No Start, Rough Idle Info (http://www.automotiveforums.com/vbulletin/showthread.php?t=450484)
List of RPO codes:
**List of RPO Codes** (http://www.automotiveforums.com/vbulletin/showthread.php?t=450285)
A little info about fuel trims:
A Little Info About Fuel Trims (http://www.automotiveforums.com/vbulletin/showthread.php?t=429831)
Purging air from your cooling system:
Got air in your heater core? Need help getting rid of it? (http://www.automotiveforums.com/vbulletin/showthread.php?t=469926)
Water cylinder decarbonization:
Water Cylinder Decarbonizing... Should I? (http://www.automotiveforums.com/vbulletin/showthread.php?t=283211)
More to come that's all I could remember right now, but I know that a lot of guys have posted some great info on here, so I'll keep looking.
Shortbus
12-02-2005, 07:16 PM
Done.
The pictures in that thread aren't working for me though :sly:
John
93LT
12-02-2005, 07:21 PM
Done.
John
Anyone else having this problem? I'd like to know if so, I'd try a different host.
blazee
12-02-2005, 07:33 PM
Done.
John
The pics are working for me. If you have a problem with pics loading, usually clicking reload will work. The forum has had a problem loading some off site pics lately.
Shortbus
12-02-2005, 07:39 PM
blazee I merged your post into the working FAQ I may have some time to work on it tomorrow.
Thank you for putting those together.
John
blazee
12-02-2005, 07:43 PM
John
You're welcome.
Thank you for organizing the forum.
OverBoardProject
12-03-2005, 01:53 AM
Most of this stuff also applies to S10's, so could you possibly paste a copy in there as well.
Thanks.
and thanks Brian
Shortbus
12-03-2005, 09:09 AM
Thanks.
and thanks Brian
Done :sunglasse
John
OverBoardProject
12-03-2005, 10:12 AM
Done :sunglasse
John
Thanks John
Brian R.
12-03-2005, 03:33 PM
Thanks.
and thanks Brian
You're welcome. It's very good Shortbus has made time for this.
blazee
12-09-2005, 05:14 PM
Ignition Switch replacement procedure (http://www.automotiveforums.com/vbulletin/showthread.php?t=287636)
First Gen Instrument Cluster Conversion (http://www.automotiveforums.com/vbulletin/showthread.php?t=489642) (covers removal and installation, too)
herkyhawki
12-11-2005, 01:13 PM
We need a technical 4x4 explanation. My guess is that the encoder motor moves a shift mechanism,which trips the vac switch to send vacuum to actator which then pulls cable to engage front axle. I'd appreciate if someone can do a write up on this. What voltages should you see at the encoder motor? how to test the encoder motor? what sensors are there to sense if it is in 2wd or 4wd. Is there a sensor to confirm front axle engagement? How to troubleshoot front hub engagement.
OverBoardProject
12-11-2005, 01:18 PM
Heres the best web page that I've seen on that subject
http://www.4x4posi-lok.com/PDFs/TSG_chevyT.pdf
Shortbus
12-13-2005, 09:57 AM
Done. :)
laxman21
12-19-2005, 12:07 AM
As suggested by another member
http://www.automotiveforums.com/vbulletin/showthread.php?t=495267
Shortbus
12-21-2005, 10:23 AM
Done.
I'm getting really frustrated at how slow Af has been lately, I would be able to do more but it really pisses me off when AF freaks out and loses my changes that I've made. Igor says he will be making some changes soon and I hope to corner him about changes to GM once again. Who knows when that will happen though.
On a positive note I did get the FAQ updated to a more user friendly interface. I just still need to add the rest of the links.
Keep them coming as you find them.
Thanks everyone for the help with this.
John
blazee
12-21-2005, 04:16 PM
I like the new layout. I edited the links in my first post to show the thread names instead of the urls, I thought that it might help you out a little when you merge them into the catergories.
A couple other suggestions:
Add a list of or link to the forum guidelines.
A statement to search the forum if the help needed isn't found in the FAQs and How-tos.
A list of what to include in threads asking for help..... Year? Engine? Is the Check engine light on? Detailed description of the problem? What has been attempted to fix it? etc.
OverBoardProject
12-21-2005, 04:24 PM
I haven't looked at what you've done blazee, but I agree with you on the sugestions.
I'd also like to see a link to the buy and sell section. Then theres no excuse for posting items on this board. It is hard to find if you don't know where to look
blazee
12-21-2005, 04:53 PM
That's a good idea.
It would also be nice to have the thread in the Jimmy and Sonoma forums too. Possibly the Bravada and Hombre forums, as well.
Shortbus
12-21-2005, 04:59 PM
That's a good idea.
Sure I can do that right now it's easy enough.
John
blazee
12-21-2005, 05:07 PM
John
Nice. :thumbsup:
OverBoardProject
12-21-2005, 05:36 PM
Thanks Shortbus!
blazee
12-22-2005, 10:49 AM
It's looking good. Thanks again for taking the time to get everything organized.
Shortbus
12-22-2005, 11:01 AM
Added at top of page :icon16:
Shortbus
12-22-2005, 11:04 AM
Could you create the page the way you want it to read and I will copy and paste it into the current FAQ?
If you want create a new topic on it and we can discuss it and fine tune before making it live on the Faq, that way you can get the credit for the post. I think its a great idea to have a general how to post faq.
Good idea :smile:
John
Once this Faq is completed in blazer I will copy it to the other forums so they are all the same.
OverBoardProject
12-22-2005, 01:13 PM
I love it Shortbus;
You've sure put a lot of effort on the new FAQ secton.
Shortbus
12-22-2005, 02:23 PM
No problem happy to help, I know I have been absent around here as a mod for almost 2 years but my work was busy at Caterpillar and know that i changed jobs again I have more time to goof on AF during work.
OverBoardProject
12-22-2005, 05:08 PM
Blazee, I really like your introduction to AF. Very well done
blazee
12-22-2005, 06:57 PM
Thanks. :smile:
I hope that it helps.
OverBoardProject
12-23-2005, 01:42 PM
I don't remember who started it, or the name of the thread but someone started a member introduction thread 2 or 3 months ago.
I know that it isn't car related, but it would almost be nice to have as a sticky. It was nice seeing a little of what everyone is like.
blazee
12-27-2005, 02:12 AM
Here's another one for you:
96+ Water Pump Replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=498467)
Shortbus
12-27-2005, 09:38 AM
Done
blazee
12-28-2005, 12:53 AM
Thanks again Shortbus.
A couple more from laxman21 :)
How to: replacing the 4x4 front differential actuator (http://www.automotiveforums.com/vbulletin/showthread.php?t=498812)
Vacuum Hoses on 4.3 TBI replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=498411)
s10blazerman4x4
12-28-2005, 01:22 PM
http://www.automotiveforums.com/vbulletin/showthread.php?p=3678681
Thats a good read their.
Tells about that 4x4 problem in first gens, thought i pass these along.
blazee
12-28-2005, 01:25 PM
Read the post right above yours. :rolleyes: :loser: :p :lol:
Shortbus
12-28-2005, 01:27 PM
Done... your welcome.
s10blazerman4x4
12-28-2005, 01:40 PM
lol i didnt see it that was scary :loser: :naughty:
blazee
12-28-2005, 01:47 PM
:screwy:
No prob, just messing with you a little bit. :loser:
s10blazerman4x4
12-28-2005, 01:54 PM
I think it was i was reading the other FAQ didnt see it so i though hum i should put this in suggestions but i dont remember seeing your post because i had a catalytic converter post open in the 3 rd window lol and i got v8 on the mind
jkdon
01-06-2006, 01:16 PM
Shortbus
How about something on the intake manifold gaskets. I remember reading a thread awhile back that had the whole procedure with pictures. I had printed it and used itmyself, and today I've been looking for it and can't find it again. I've been searching for it all day. this info may help some others out. I'm gonna keep looking. Great job with this Fag thread, saves a ton of time.
thanks
JKdon
billibong
01-06-2006, 01:31 PM
JKdon, you may want to reread your post and edit. :icon16: Just a little mistype there, it's actually kind of funny.... :p :p :thumbsup:
blazee
01-06-2006, 01:33 PM
Shortbus
How about something on the intake manifold gaskets. I remember reading a thread awhile back that had the whole procedure with pictures. I had printed it and used itmyself, and today I've been looking for it and can't find it again. I've been searching for it all day. this info may help some others out. I'm gonna keep looking. Great job with this Fag thread , saves a ton of time.
thanks
JKdon
:lol:
http://www.automotiveforums.com/vbulletin/showthread.php?t=486234
Shortbus
01-06-2006, 02:30 PM
Fag thread LOL.
I love it!
Shortbus
01-06-2006, 02:33 PM
:lol:
Added
blazee
01-06-2006, 02:40 PM
Added
:thumbsup: Thanks again.
I didn't see it when it was posted or I would have recommended it, it's a good thing that jkdon said something.
Nice Job Cailen.
ZL1power69
01-08-2006, 07:57 PM
i got 2 for u to add Shortbus, both by our budy rlith;
- How-to change the PITA #3 spark plug
http://www.automotiveforums.com/vbulletin/showthread.php?t=503231
- Another CPI How-to (focus on regulator)
http://www.automotiveforums.com/vbulletin/showthread.php?t=503238
Shortbus
01-09-2006, 10:24 AM
Ok I got them added thank you.
blazee
01-09-2006, 04:18 PM
Here's a couple more for you:
Heater System: Information, Troubleshooting, And Repair (http://www.automotiveforums.com/vbulletin/showthread.php?t=503195)
Steering System: Information, Troubleshooting, and Repair (http://www.automotiveforums.com/vbulletin/showthread.php?t=503647)
Shortbus
01-09-2006, 05:58 PM
Ok done deal. Guess I need to update the other S & T body forums to.
OverBoardProject
01-12-2006, 12:01 PM
how about this thread Shortbus
http://www.automotiveforums.com/vbulletin/showthread.php?p=3715890
I know that it isn't a comon problem but still think that it deserves a place in the body section. plus most internal cab leaks are caused by blockage
ZL1power69
01-21-2006, 11:59 PM
heres another one for ya. its a how-to by rlith about steering slop.
http://www.automotiveforums.com/vbulletin/showthread.php?t=510605
blazee
01-22-2006, 07:23 AM
Done.
s10blazerman4x4
01-26-2006, 01:05 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=379971&highlight=convert+cluster
What about that didnt notice that in the Interior section of the FAQ another nice one by Rlith back in the day.
nickledimed
01-31-2006, 02:38 AM
I was wondering if you could put a link to a good A/C component break down and the procedures for diagnostics.
Also I have the Electronic Climate Controles on my 98 Blazer, that would be a very interesting topic. The thing sure is acting weard...when the truck is running I can hear the actuator trying to move the a/c\heater vent to heat when it is already in heat...i know its in the electronic module in the switch.
I can not get it to go to cold unless I pinch one of the tubes connected to the vacume manifold under the dash.....I am also losing r-134 somewere but I cannot find the leak. Ive used dye and still cant find the leak...I hope I didnt go to far off topic...if soo...sorry.
PS....Best s10 site I have ever found....all the others argue and dis eachother...keep up the good work.
Shortbus
02-03-2006, 05:22 PM
Done :sunglasse
Shortbus
02-03-2006, 05:25 PM
I'll keep my eye out for such a topic or thread.
Thank you for the complement, its the members in here that make it what it is.
OverBoardProject
03-02-2006, 06:23 PM
Not the best gramer in the world (sorry) but does this one qualify?
how to improve your ride quality
http://www.automotiveforums.com/vbulletin/showthread.php?p=3876616#post3876616
blazee
03-03-2006, 05:56 PM
Done
