Read First - FAQ & how to thread!!
Shortbus
12-02-2005, 05:16 PM
Frequently asked questions and How-to's for GM S/T bodys Special thanks to blazee, OverBoardProject,93LT,laxman21,Brian R., and the thread creators as well as anyone else I missed.
Click links below for how to sections
Please report any dead links to shortbus@af via PM or any other questions about this faq, John
Selling your Car?, Have spare parts for sale?, Post them Here (http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=1269)
Body/Paint Exterior
Rust repair around windsheild (http://www.automotiveforums.com/vbulletin/showthread.php?t=495267)
Replacing door hinge pins and bushings. (http://www.automotiveforums.com/vbulletin/showthread.php?t=363334)
Replacing door hinge pins and bushings Illustraded (http://www.automotiveforums.com/vbulletin/showthread.php?t=476619)
Restore your weathered plastic how-to (http://www.automotiveforums.com/vbulletin/showthread.php?t=391672)
Engine Performance/Diagnostics
4.3 CPI Injector replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=473110&highlight=4.3+CPI)
***92 - 95 CPI Engine Info.*** (http://www.automotiveforums.com/vbulletin/showthread.php?t=462726)
Fuel economy and General Maintenence reccomendations (http://www.automotiveforums.com/vbulletin/showthread.php?t=453370)
List of OBD II Codes (http://www.automotiveforums.com/vbulletin/showthread.php?t=425701)
Basic Cooling System Advice (http://www.automotiveforums.com/vbulletin/showthread.php?t=456944)
Got air in your heater core? Need help getting rid of it? (http://www.automotiveforums.com/vbulletin/showthread.php?t=469926)
Water Cylinder Decarbonizing... Should I? (http://www.automotiveforums.com/vbulletin/showthread.php?t=283211)
A Little Info About Fuel Trims (http://www.automotiveforums.com/vbulletin/showthread.php?t=429831)
96+ Hard Start, No Start, Rough Idle Info (http://www.automotiveforums.com/vbulletin/showthread.php?t=450484)
Brakes, Suspension, and Drivetrain
1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!! (http://www.automotiveforums.com/vbulletin/showthread.php?t=302656)
Drum to Disc brake rear end swap how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=372515)
Transmission Problems: Common Issues and Solutions (http://www.automotiveforums.com/vbulletin/showthread.php?t=461182)
Read for Help **ABS Activation At Low Speeds** (http://www.automotiveforums.com/vbulletin/showthread.php?t=425516)
Ignition Electrical and Wiring System
First Gen Instrument Cluster Conversion (http://www.automotiveforums.com/vbulletin/showthread.php?t=489642)
Ignition Switch replacement procedure (http://www.automotiveforums.com/vbulletin/showthread.php?t=287636)
Heated seat how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=366533)
Factory fog lamp switch with non factory fog lamps. (http://www.automotiveforums.com/vbulletin/showthread.php?t=356665)
Everything Interior/ Audio
