i have code 23 but...imasleep 12-02-2005, 03:52 PM I have code 23.. but i do not hear any knocks. I re-set the light and the code keeps coming back. I have a CRX with a GSR B18-C1/0BD1 Thanx ImAsleep superbluecivicsi 12-02-2005, 05:42 PM the knock sensor cel has nothing to do with your engine knocking. its a malfunction with the operation of the knock sensor. check the wiring, ecu, or knock sensor itself. imasleep 12-02-2005, 10:04 PM Thanx for the info! thanx imasleep fussball84 12-11-2005, 04:53 PM Knock Sensor OPERATION When knocking occurs, the weight in the cylinder case moves, causing the piezo electric element in the KS to translate the vibration into an electric voltage. A signal is then transmitted from the KS to the ECU. In response, the control unit retards spark timing to prevent engine knocking. On the Loyale with Multi-Point Fuel Injection (MPFI), the KS is located on top right-side of the cylinder block and senses knock signals from each cylinder. On the Legacy and Imprezas the KS is installed on top left-side of the cylinder block and senses knock signals from each cylinder. The SVX is equipped with 2 knock sensors; both are located on top of the cylinder block one on the right side and one on the left side. superbluecivicsi 12-11-2005, 05:11 PM he specifically stated that he has a b18c1. which means his knock sensor is right above the oil filter. Automotive Network, Inc., Copyright ©2012
