Left Turn Signal
Blkrodeo
12-02-2005, 10:09 AM
I have a 1995.5 Rodeo. My left turn signal stays on, only when I turn my head lights on. With headlights off the turn signal works fine. Can anyone point me in the right direction?
amigo-2k
12-02-2005, 12:26 PM
1. if you have a trailer harness unplug it.
2. pull the bulbs and change and/or clean them.
Blkrodeo
12-02-2005, 12:33 PM
Do you mean all the bulbs?
Canucklehead
12-02-2005, 12:57 PM
Did you just get this Rodeo or has it just started doing this? Vehicle history helps. :smokin:
When you say the turn signal stays on do you mean it blinks continuously or just stays solid?
Could be oxidation on the bulbs or sockets, a problem in your trailer wiring (as Ryan suggested) then again it could be a bad combination switch.
Blkrodeo
12-02-2005, 01:12 PM
Light stays solid. I've had it the past two years, only had to change starter and that was two months ago. Front left turn bulb was blown and I replaced it with a brand new bulb. The rear left turn signal stays solid when I cut on headlights. With headlights off , works fine.
Canucklehead
12-02-2005, 01:21 PM
You may have put the wrong bulb in the front turn signal socket. You can try switching the two front bulbs and seeing if the problem moves to the right side.
Blkrodeo
12-08-2005, 01:07 PM
Update, swapped bulbs and all, even replaced with new ones, same problem, but also with out the headlights on, and I hit the left turn signal, the left turn signal flashes like its suppose to, and the right front side marker and front fender flashes also. With headlights on the left stays illuminated.......any ideas.
thekicker20
03-02-2006, 03:23 PM
2001 4wd V-6 Rodeo LS
I just had the same thing happen to me today. I replaced the drivers-side bulb (since the old one wasn't working). The bulb works fine. In fact, everything works fine, except, when I turn on my headlights the left turn signal (dashboard) comes on and says on (solid not flashing).
Any ideas?
Blkrodeo
03-03-2006, 03:48 PM
Believe problem lies in the steering column switch, however my problem just went away on its own..........noticed on some really cold morninings it happens but goes away................
directory
03-03-2006, 04:33 PM
i think it's time to start tracing wires. strat form the bulb and work you way back. look for pinches, rubs, etc. check all connections, switches, relays.
