Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 12-02-2005, 12:39 AM   #1
sragonzo
sragonzo Normal reputation
Engine problems
I have a 96 plymouth neon with 104,000 miles. My after market parts are Iceman intake, bored throttle body, MSD coil and 8.5 wires, Crane 16 cams, 2.4 lifters and rocker arms, Unorthodox pulley, Fidanza gears, Hedman header to a full exhaust system. My engine want to stall when i come to a stop, right now i have the engine light on with the code 43 ( multiple engine misfire detected peak primary circuit current not achived with the maximum dwell time) I have the champion spark plugs installed already. I wounder if the cams are cousing this problem. I also have that tapping sound coming from my #1 cylinder but i already replaced my lifters and rocker arms and the tapping is still their. If anybody can help i would like.
sragonzo is offline   Reply With Quote
Old 12-02-2005, 08:43 AM   #2
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Engine problems
Did you recently change them? Gapped correct? Maybe its time for some new ones.
das2123 is offline   Reply With Quote
Old 12-02-2005, 06:35 PM   #3
sragonzo
I replaced them some time in the summer, but the Hayes book has them gapped at .050 and Auto Zone says .035. I have them at .035 right now.
Old 12-03-2005, 10:24 AM   #4
das2123
das2123's Avatar
Re: Engine problems
Did that help your misfire?
Old 12-03-2005, 12:19 PM   #5
sragonzo
nope those are the same ones from the summer. Im going to Autozone to buy some new ones but ill gap these to .050.
Old 12-03-2005, 09:56 PM   #6
97 neon
97 neon Normal reputation
Re: Engine problems
bad idea
97 neon is offline   Reply With Quote
Old 12-04-2005, 01:29 AM   #7
sragonzo
why is that. Hayes book says to gap it to .050
Old 12-04-2005, 11:08 AM   #8
das2123
das2123's Avatar
Re: Engine problems
The correct spark plug gap is 0.035" for both engines. Note that the Haynes manual has an incorrect gap specified for the DOHC.
Old 12-12-2005, 06:31 PM   #9
sragonzo
Re: Engine problems
I replaced those plugs last saturday and the engine came on yesterday. They are gaped to .035 and it wont give me and engine code i waited for about 30 seconds. Can anybody help me.
Old 12-12-2005, 08:16 PM   #10
Turbodog97
Just a Neon
Turbodog97's Avatar
Turbodog97 Normal reputation
Code 43..... Misfire on one or more cylinders detected. Spark plug, injector, cylinder compression or air intake problem; primary circuit problem in one or both ignition coils
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Turbodog97 is offline   Reply With Quote
Old 12-12-2005, 11:37 PM   #11
das2123
das2123's Avatar
Re: Re: Engine problems
Did you reset the PCM after you installed the new plugs?
Old 12-13-2005, 07:56 PM   #12
sragonzo
Re: Engine problems
I replaced the coil about 3-4 months ago with a new one from msd coil and msd wires. I removed the negative cable on the battery for about 3-5 minutes while i replaced the plugs. Im going to have to look at the injectores and replace my K&N filter
Old 12-13-2005, 09:43 PM   #13
das2123
das2123's Avatar
Re: Engine problems
I doubt it's a fuel injector problem giving you a code 43. Check the coil pack for any cracks and make sure the wires are tight. Also check the wires for any frayed parts. Disconnect your fuel pump fuse for about 15 minutes, just to make sure that the codes are clearing.
Old 12-13-2005, 10:41 PM   #14
sragonzo
Re: Engine problems
the car never gave me a code 43 the engine light turned off when I did the on-off-on-off-on. I didnt blink at all. The fuel pump fuse is under the hood behind the battery.
Old 12-13-2005, 11:27 PM   #15
99 Neon R/T
99 Neon R/T Normal reputation
Re: Engine problems
when you did the key dance the light should have at least given you a 55 end of codes.As for the ticking in the #1 cylinder could be a faulty spark plug boot.If there is even the smallest crack or hole in the insulation then the spark will arc off of the valve cover or the cylinder head inside the tube and cause a ticking noise.What you want to look for on that is a white spot anywhere on the spark plug boot that will indicate a burn spot which is a sign of arcing.I hope that helps you.
If it aint broke fix it till it is.
99 Neon R/T is offline   Reply With Quote
Bookmarks
Google
Web AF
