Need Help Pleasecndoliver 11-30-2005, 10:56 PM I have a 97 JGC 5.2 all-time 4 wheel drive The idle has been acting up but it now has started it cut off just driving down the road So I am trying to replace the CPS and can not figure it out I have read the other post I also have the haynes book But I cant get my arm up in the hole So could someone PLEASE tell me how What size is the nut what do I need to use socket wrench or what and how to get to it before I have to have it towed to the stealership Thanks :banghead: MT-2500 11-30-2005, 11:54 PM Your best bet is to get a scanner on it and check it out and find out for sure what it is. MT dksob81 12-01-2005, 07:14 AM On the 5.2L Engine the CPS is on the passengerside engine block behind the right cylinder head. You will need to remove the CPS from the top of the engine (can't get to it from under the jeep. There are 2 bolts to the CPS (I believe they are 8mm-10mm don't quote me, can't remember exactly). -Remove the plug wire on the passenger side and mark them for each cylinder, -Remove the passengerside exhaust manifold heatshield and remove the EGR Exhaust tube from the exhaust manifold and from the intake manifold. -now feel down behind the cylinder head for the CPS, it's down about a foot maybe a lil more. Once you feel it it will make it easier to get to to remove. -using a series of extensions and the appropriate socket remove the 2 bolts from the CPS and pull it out. I know this seems like alot of work but it isn't really to bad, my forearms are pretty big and I got my arms down in there. cndoliver 12-01-2005, 05:27 PM OK I finally got it out and changed with a 1/2 socket and 1/4 allen wrench Thanks for the help Automotive Network, Inc., Copyright ©2012
