96 Stratus stalling problemssaddriver 11-30-2005, 09:14 AM Just bought a used 96 Stratus, and the engine has stalled a few times while driving on the highway. No warning, just shut off. Lights stayed on, so was not the battery. Pulled over, and car would not start. 5 minutes later it started. This has happened a couple of times. There was also a message showing on the odometer when trying to start "NO BUS". Dealership did not find anything wrong after hooking up the the computer. Need help. Any suggestions? xxxjayluvxxx 12-04-2005, 07:48 PM well something like this happened to me before and it was the electrical wiring going to the coil. the clip on the wiring was broken off and when i would hit a bump the wiring would loosen and make my car die. theFREAKnasty82 12-05-2005, 07:03 AM Just bought a used 96 Stratus, and the engine has stalled a few times while driving on the highway. No warning, just shut off. Lights stayed on, so was not the battery. Pulled over, and car would not start. 5 minutes later it started. This has happened a couple of times. There was also a message showing on the odometer when trying to start "NO BUS". Dealership did not find anything wrong after hooking up the the computer. Need help. Any suggestions? "NO BUS" usually means that there is a communication problem between the modules. Have them, or you, check the connections at the engine computer under your hood, driver's side fenderwell. Also have the connections checked at the body control module, passenger compartment, passenger side inner kick panel. It could be something, (I've seen this before) as simple as a bad instrument panel not making good contact thus your vehicle loosing it's "BUS" or comm signal. theFREAKnasty82 12-05-2005, 07:03 AM Just bought a used 96 Stratus, and the engine has stalled a few times while driving on the highway. No warning, just shut off. Lights stayed on, so was not the battery. Pulled over, and car would not start. 5 minutes later it started. This has happened a couple of times. There was also a message showing on the odometer when trying to start "NO BUS". Dealership did not find anything wrong after hooking up the the computer. Need help. Any suggestions? "NO BUS" usually means that there is a communication problem between the modules. Have them, or you, check the connections at the engine computer under your hood, driver's side fenderwell. Also have the connections checked at the body control module, passenger compartment, passenger side inner kick panel. It could be something, (I've seen this before) as simple as a bad instrument panel not making good contact thus your vehicle loosing it's "BUS" or comm signal. The I.C.'s are notorious for going bad on these cars. saddriver 12-05-2005, 12:06 PM "NO BUS" usually means that there is a communication problem between the modules. Have them, or you, check the connections at the engine computer under your hood, driver's side fenderwell. Also have the connections checked at the body control module, passenger compartment, passenger side inner kick panel. It could be something, (I've seen this before) as simple as a bad instrument panel not making good contact thus your vehicle loosing it's "BUS" or comm signal. When the car would not start, the "NO BUS" signal was being displayed on the odometer, but once I got it started and brought down to the dealer right away, they had told me the "no bus" signal was from 65 starts ago. Would this imply the car not starting at this time, was not due to a communication problem????????? theFREAKnasty82 12-05-2005, 11:08 PM what happens 65 start-ups ago usually doesn't have a major bearing on the current start-up cycle. If the modules can't talk, the car won't start; like if your spinal cord is injured, you'll loose feeling to one or more of your extremities in your body, same with the bus signal with your car. What the dealer is telling is half-right. The 65 start-up is not necessarily true. It really sounds like a bad connection somewhere, more than likely in your instrument cluster itself where there is corrosion or something else going screwy. Automotive Network, Inc., Copyright ©2012
