97 jimmy axle seal replacementstressfree 11-30-2005, 07:14 AM whats involved? JIMMY92w 11-30-2005, 10:58 PM 1. Buy new seals 2. Take off axle 3. Swap out seals 4. Put back together rlith 12-01-2005, 07:17 AM 1. Buy new seals 2. Take off axle 3. Swap out seals 4. Put back together Not so quite cut and dried... Jack up truck Pull diff cover and drain Remove brake drums/calipers and mounting frames Remove lock pin holding the pinion in place and remove pinion remove c clips holding axels in place Pull axel shaft and set aside Remove old seal using a screwdriver or seal remover (remover is better) Tap new one in carefully using hammer and like size socket Lightly lube the new seal Install everything in reverse Spray out pumpkin with brake klean Scrape pumpkin with razor blade until EVERY LAST SINGLE BIT OF OLD GASKET IS GONE Hand tighten cover with new gasket in cross pattern Refill pumpkin stressfree 12-02-2005, 01:15 PM thanks thats almost like a ford f-150.pull rear cover take out c clip.thanks. rlith 12-02-2005, 03:35 PM Most diff's are the same regardless of manufacturer.. stressfree 12-05-2005, 08:01 AM thanks,on that jimmys my fuel gauge is off big time.is that a jimmy thing. rlith 12-05-2005, 09:31 AM thanks,on that jimmys my fuel gauge is off big time.is that a jimmy thing. It's a typical s/t truck thing Automotive Network, Inc., Copyright ©2012
