93 S-10 squeak/chirp
joejoekj
11-29-2005, 11:39 PM
I have a: 1993 S-10 4x4 4.3L with 163,000 mi
that squeaks in the front end while in park, while idleing, and while driving.
Not all the time, but about 80% of the time and it's driving me nuts.
I do know that it is NOT the alternator, tensioner, water pump, or belt,
but the noise is coming from somewhere near them.
I know this because I've had to replace all of these separately as they
have gone bad. After I got done fixing each of these, I was hoping that
the squeak would be gone... but the sqeak remains.
With the last project, the water pump, I started it without the belt on
and let it run for a few seconds... still the squeak remains even without the belt!
My last idea is that it is coming from the pully that drives the belt, but I
didn't want to try to take that off without being sure how to fix it since
it goes into the motor/transmission?
I have repeatedly tried spraying WD-40 on this remaining pully, which
quiets it a little for a few seconds... but the squeak remains.
Any advice would be helpful. Keep in mind I don't really know jack,
but I'm pretty good at taking things apart, finding what's broken, and
putting the new parts on.
laxman21
11-29-2005, 11:46 PM
I would try spraying a little lubricant on the suspect pully and see if the squeek goes away. Then you will know thw offwnding part.
Gabe25
11-30-2005, 03:25 AM
If the squeak is still there with the belt off, Then you should be looking for a possible vibration squeak. It can't be the pully's. No belt to turn them. Try taking a look at your upper and lower control arm bushings. That year has been know to squeak. Good luck!!!!
BlazerLT
11-30-2005, 11:44 AM
Just make sure you don't get the lubricant near the belt itself.
Also, grease your front and and check your motor mounts.
