Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Cars in General > Light Trucks and Minivans > Pickup Trucks
Old 11-29-2005, 08:30 PM   #1
j_av18
j_av18 Normal reputation
1998 chevy pickup not starting but turns over and fires
i'm having problems with my 1998 chevy pick up not starting. it turns over rough,it fires a couple of times but wont run. I replaced the fuel pump for the second time 5000 miles ago. I can hear the pump running whe the ignition is on but, it just wont run. Plug were can 5000 miles ago as well. I put a code reader on it but no codes come up can anyone help. thanks josh
j_av18 is offline   Reply With Quote
Old 12-02-2005, 11:11 PM   #2
j_av18
Re: 1998 chevy pickup not starting but turns over and fires
well i let the truck sit for two days and it started right up. I let it run for awhile. then shut it off. later on when i went to the store as soon as i started it up it made a loud bang but seems to run fine. Does anyone think I need to take it in for some dianostics. thank you.
Old 12-05-2005, 07:00 PM   #3
BleedDodge
BleedDodge's Avatar
BleedDodge Normal reputation
Send a message via MSN to BleedDodge
Got a catalytic converter on it? I bet you it's plugging up.
My Mopars
BleedDodge is offline   Reply With Quote
Old 12-17-2005, 10:30 AM   #4
BlackDog69
BlackDog69 Normal reputation
Re: Re: 1998 chevy pickup not starting but turns over and fires
I have a similar problem with my 96 pickup. It will turn over just fine, but won't fire. After I let off the starter, it will fire a couple of times on one cylinder. Had it brought to a garage, started with no problem, they could not duplicate, although they did pull the plugs and thought it was running a bit rich. I drove the truck home Friday and let it sit the weekend. Monday, no start again. The garage came and it wouldn't start for them either. They put a gauge on it and said it had 60+PSI fuel pressure. They dragged it back to the shop and tinkered with it for a while. The next day it started just fine! I'm at a loss, they are at a loss, and my truck is unreliable. Any thoughts?
BlackDog69 is offline   Reply With Quote
Old 05-04-2006, 11:54 AM   #5
snowleopard
snowleopard Normal reputation
try the cam or crank sensers and retime
snowleopard is offline   Reply With Quote
Bookmarks
Google
Web AF
