Front Wheel Bearingsrapposm 11-29-2005, 07:32 PM I own a 1998 GMC Jimmy and need to know how difficult it is to replace the front wheel bearings, is this something that can be done at home or has to be done in a shop. Does any have a link to any web site that outlines the steps? Thanks, rlith 11-30-2005, 10:08 AM I own a 1998 GMC Jimmy and need to know how difficult it is to replace the front wheel bearings, is this something that can be done at home or has to be done in a shop. Does any have a link to any web site that outlines the steps? Thanks, Pretty easy... Only needed tools 18mm box wrench and socket 36mm socket BFG (Big farkin hammer) Jack 19mm socket or lug wrench torque wrench (hub nut must be at 180 ft pounds) rapposm 12-02-2005, 07:46 PM Is their an esay way to tell which bearing needs to be replaced, or should I just replace both of them? rlith 12-02-2005, 08:07 PM you can jack the wheel up then move it from left to right and top to bottom while having someone watch the hub from the back. While you still can't always tell it's worth a try. For me though I would replace both hubs. BlazerLT 12-03-2005, 12:16 AM Is their an esay way to tell which bearing needs to be replaced, or should I just replace both of them? On the highway, turn slightly to the left and right. Turning left loads the right bearing and vise versa. If you turn left at highway speed and it howls or roars (not like a dog or lion ;)), the right bearing is bad. Turning right and the noise coming about means the left bearing is bad. scnvsleep 12-04-2005, 09:32 AM On the highway, turn slightly to the left and right. Turning left loads the right bearing and vise versa. If you turn left at highway speed and it howls or roars (not like a dog or lion ;)), the right bearing is bad. Turning right and the noise coming about means the left bearing is bad. Does this method apply to a 2001 Jimmy 2WD with the sealed hub bearing assemblies? BlazerLT 12-04-2005, 04:48 PM Applies to all vehicles with bearings. scnvsleep 12-07-2005, 11:28 PM OK...so riddle me this...I have the howl driving straight and when I turn left. When I turn right, it goes away...left bearing bad? Or is it both simultaneous...? BlazerLT 12-08-2005, 12:43 AM OK...so riddle me this...I have the howl driving straight and when I turn left. When I turn right, it goes away...left bearing bad? Or is it both simultaneous...? Right bearing, when you turn left, you load the right bearing. scnvsleep 12-09-2005, 09:36 PM Right bearing, when you turn left, you load the right bearing. Bizarre....but I've spent too much time lurking and reading (and successfully following advice) on this board to question you guys. Thanks! BlazerLT 12-09-2005, 10:26 PM Bizarre....but I've spent too much time lurking and reading (and successfully following advice) on this board to question you guys. Thanks! Just think of it, when you turn left the weight shifts to the ouside tire right which will be the right tire. This loads the tire and the bearing. cmoore992002 12-15-2005, 10:54 AM I just replaced the front wheel bearings on my '92 Jimmy. The job is easy. The howling that the previous posters mentioned went away immediately. The truck has about 146,000 miles and the bearings I replaced were probably the originals. BTW I would replace all of them. Trying to figure out which one is bad is too tough. When I took the old ones off they all looked good. Good luck. BlazerLT 12-15-2005, 03:36 PM Was it a 2wd? cmoore992002 12-16-2005, 07:02 AM Yes it is a 2WD. If this thread referred to 4WD I apologize. BlazerLT 12-16-2005, 05:02 PM Yes it is a 2WD. If this thread referred to 4WD I apologize. Oh no, just making sure a person knows before they go in thinking a 4wd front bearing replacement is easy. ;) Completely different ball of wax when you have driveline components to deal with. halle 12-17-2005, 07:42 AM Pretty easy... Only needed tools 18mm box wrench and socket 36mm socket BFG (Big farkin hammer) Jack 19mm socket or lug wrench torque wrench (hub nut must be at 180 ft pounds) the BFH sure came in handy. total time spent was about 3.5 hrs both sides thanks alot! Automotive Network, Inc., Copyright ©2012
