both turn signals and hazzard lights failedjmeade 11-29-2005, 03:29 PM 2000 gmc jimmy. both my turn signals and hazzard lights and brake lights, went out at same time. i have checked all the fuses, and none of them are burned out. changed then anyway. anyone have any suggestions?? chembrad 11-29-2005, 06:49 PM check your fuses. Probably blown. prblmslv 03-28-2006, 07:33 PM Hello, This may be too late to an old posted problem, but will add this anyway. I had a problem there, and it was not anything you would normally do. I had to wiggle the hazzard switch...get it in the right spot, then everything would work again!! infact I have a pen cap in it to keep it in the forward position..this allows all lights to work. It seems to be a common GM thing... Good luck to those who may read this 95xjsport 03-29-2006, 11:03 PM Is there any way to by pass the hazard switch? min does that and I can;t find one any where... prblmslv 03-30-2006, 07:41 AM Hello Again, Umm first I need to understand one thing, Did you try the trick I mentioned? If so, I am assuming that it was it and you found that if the hazzard swiitch is in a special "spot" everything else will work, brake lights...directionals...etc??? Well, this is all I can tell you and help you with, I sprayed mine with an electronic cleaner and removed the pen cap holding the hazzard switch forward...So far all is working. I have NEVER and will NEVER touch the hazzard switch even if I need it! Perhaps someone out there has gone deeper into this matter, if so I would also like to know what they say. Wish I could help you more. Please keep me in the loop if someone responds with a cool solution to this matter ...Thanks and Good LUCK! Doug 95xjsport 03-30-2006, 02:39 PM I actually dont have the hazzard switch well, I have half of it, its is still in the column. I tried wiggling it, moving it around, I can get them to work but, it dosn;t last long one bump and its messed up again... blazee 03-30-2006, 09:02 PM The hazzard switch is built into the multifunction switch. This switch can be bought at just about any parts store for about $150. The grease used in the switches eventually runs down into the contacts, shorting them out and causing improper operation. If the hazzard button itself is physically broken, it can be replaced. The chevy dealer sells a replacement button for less than $20. Here's the replacement procedure for a broken button: http://www.blazinlow.com/forum/showthread.php?s=&threadid=32757&highlight=Broken%2BHazard%2BSwitch RI1470 04-16-2006, 05:58 PM I know that I'm a little late to this party, but I had the same problem on my 2000 Jimmy SLT. Take the Jimmy to a dealer and get the recall fixed. There was a voluntary recall on this issue, but GM was not obliged to notify owners. Have the dealer run the VIN and see if it was ever done. If it wasn't it's a free repair. I only found out about this after I was pulled over by a cop for no brake lights. excheezhead 04-18-2006, 09:55 AM I know that I'm a little late to this party, but I had the same problem on my 2000 Jimmy SLT. Take the Jimmy to a dealer and get the recall fixed. There was a voluntary recall on this issue, but GM was not obliged to notify owners. Have the dealer run the VIN and see if it was ever done. If it wasn't it's a free repair. I only found out about this after I was pulled over by a cop for no brake lights. exactly right !!! this was the exact symptom for the blazer/jimmy recall 6 months after i bought my 01 brand new. it is actually a fire in the steering column(?) and the recall was for a lot of vehicles from gm. i was nofified by the delership to get it done at no cost asap,it got picked up by the media, and the NHTSI and consumer reports jumped on it. i did the same thing, found out that jamming a pen cap to the right on the flasher switch worked, but the recall fixed it and no trouble since, 5 years and still going. Automotive Network, Inc., Copyright ©2012
