Wireless Key fob
sprindl
11-29-2005, 12:48 PM
Anyone know of a vendor who sells these for a 2000 s-10 Blazer that is not charging $90.00 for the Fob and $90.00 to program the darn thing?
-sp
Cailen
11-29-2005, 01:33 PM
Pulled this from another thread re: a 98 Blazer keyless entry:
Wrong instructions...
PROGRAMMING INSTRUCTIONS
All Extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Transmitter Programming:
1) With the driver door closed, hold down the power UNLOCK button on the door panel.
2) Turn the ignition switch to the ON position.
3) Turn the ignition switch to the OFF position.
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Release the power unlock button on the door panel. The remote control door lock receiver will respond by cycling the locks to indicate the receiver is in the programming mode.
7) Hold down the lock and unlock button on the transmitter for about 30 seconds. The locks will again cycle to confirm programming.
- REPEAT step 7 for each additional transmitter.
8) Turn the ignition to the ON position in order to exit the transmitter programming mode.
I picked up my keyless remotes from this site cheap, >>> www.thepartsyouneed.com
They worked great, plus, she's hot! haha.
xjcamaro89
11-29-2005, 01:43 PM
Try checking on ebay, most of the time you can find someone with a FOB for sale and they provide you with programming instructions too. Good luck!
sprindl
11-29-2005, 01:59 PM
Good stuff, Thanks
-sp
Onblsht
12-04-2005, 07:10 PM
Yes, the 98-02 Blazers use the same instructions.
