Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 11-28-2005, 09:39 PM   #1
paco16
paco16 Normal reputation
Need instructions for installing oil cooler lines
I need to replace the oil cooler line that connects from the engine block to the oil filter housing. I have accomplished replacing the oil cooler line connecting from the radiator to oil filter housing. Does anyone have any instructions on how to do that?
paco16 is offline   Reply With Quote
Old 11-28-2005, 09:48 PM   #2
laxman21
laxman21's Avatar
laxman21 Normal reputation
Re: Need instructions for installing oil cooler lines
What year? I have done it in a 92.
laxman21 is offline   Reply With Quote
Old 11-28-2005, 10:27 PM   #3
blazer_guy86
blazer_guy86's Avatar
blazer_guy86 Normal reputation
Correct me if i'm wrong, but i think the set up is basically the same for all the 4.3's. I've changed them on a 94 and also on my 98.
But changing them isn't hard. On the radiator where the lines enter there are 2 pin clamp thingy's you'll have to take off with a pair of pliers. You will also have like a support about half way down the line you'll have to remove. Then there's one bolt right above your oil filter you'll have to remove. At this point the whole line should just come out. I'm not entirely sure if you have to drain the oil or not but i don't think you do. Just be sure you get the gasket with the new lines. DO NOT use the old one. And common sense would tell you to do this while the engine is cool. it's much easier, i promise. Good luck and hope this helps.
blazer_guy86 is offline   Reply With Quote
Old 11-29-2005, 07:34 AM   #4
Lt_Dusty
Lt_Dusty Normal reputation
I believe he is talking about the other line from filter to engine block.
I just did this on our 96 Blazer. It wasn't too difficult, but aggrevating. You will need a series of extensions to get at the bolt on the engine block. I came in from the front of the motor. I also had to jack the motor up a bit to get the old line out and slide the new line in, also from the front. I jacked it up with a floor jack and a piece of wood on the oil pan. Probably not the safest or smartest way on an aluminum pan, but it doesn't need to move very much at all. I'm sure if I did it again it wouldn't be nearly as bad as going in blind. Just be sure as you tighten the bolts that everything is lined up properly. I also (finally) used a piece of paper towel in my socket to hold the bolt while I finaggled it back in to the mount.
Lt_Dusty is offline   Reply With Quote
Old 11-30-2005, 08:05 PM   #5
paco16
Re: Re: Need instructions for installing oil cooler lines
It's on a 2000 chevy blazer
Old 11-30-2005, 08:19 PM   #6
paco16
thanks 4 the info my chev blazer is a 2000 ill be working on it later on this week id rather do it myself than pay someone 500.00 and change.i was told i will have to jack up the engine an inch or so to get the lines through is that true? oh yeah ill be sure and let it cool down first hahaha thanks paco16
Old 11-30-2005, 08:35 PM   #7
paco16
Lt.-Dusty did you take the motor mounts out before you jacked it up and is there some where else besides the oil pan to jack it up on? i know the first question sounds stupid but on my 65 chevy you can jack it up a little without taking out the motor mount bolts thanks LT Dusty.
Old 12-01-2005, 05:20 AM   #8
Lt_Dusty
Hi Paco,
No I did not remove any motormounts. They looked like more trouble to do than changing the Oil line. You might not have to jack the motor at all. It was so close that I only had to put some pressure on the motor to get the new line in. Actually I got the old one out without jacking, but the new one seemed to be just a little larger. I couldn't tell by compairing, but I just couldn't seem to fish it in. I'm sure you could find an other spot to jack that would be a little safer, but like I said you might not have to.
Old 12-01-2005, 10:20 AM   #9
laxman21
laxman21's Avatar
Re: Re: Re: Need instructions for installing oil cooler lines
Set up is diffrent than mine. My oil filter is on the driver's side fender. Easy to get too.
Old 12-02-2005, 03:31 PM   #10
pernicev
pernicev's Avatar
pernicev Normal reputation
Checked the archives, lots of info. I did it 2 years ago based on what I found there. Basically on my 98 I had to put a jack under the engine to lift it about a half inch or so. You do not need to take off the motor mounts or anything else but the oil lines themselves.
pernicev is offline   Reply With Quote
Old 12-07-2005, 10:09 AM   #11
paco16
Alright Lt Dusty and everyone else whom is trying to help me get this part fixed, I have a problem. The part that I ordered on line is the wrong part. When I talked to the mechanic at the shop I took it to he said I needed to replace the oil cooler lines. When I started checking into parts I had a couple places ask me if they were the upper or lower oil cooler lines. When I asked the mechanic he said it was 2 lines... one from the motor mount to the oil housing and the other from the oil housing to the radiator. Does anyone know where I can get the correct lines that he's talking about? disturbed and disgusted paco16
Old 12-07-2005, 10:10 AM   #12
paco16
Re: Re: Re: Re: Need instructions for installing oil cooler lines
Old 12-07-2005, 10:12 AM   #13
paco16
Old 12-07-2005, 10:46 AM   #14
laxman21
laxman21's Avatar
Go to a dealer parts dept. Sometimes its the best place. They actually walked outside and checked my truck to make sure it was the right part.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 12-07-2005, 10:56 AM   #15
Gabe25
Gabe25's Avatar
Gabe25 Normal reputation
Here see if this will help in finding the right lines to be replaced.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Gabe25 is offline   Reply With Quote
Bookmarks
Google
Web AF
