Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 11-28-2005, 06:59 PM   #1
mikes96neon
mikes96neon Normal reputation
new head?
wasup, i own a 96 sohc neon and i would like to replace the head. If you have any information or know someone who has replaced their head on a neon please inform me.I would like to replacie it with a dohc head, srt 4 head, or any 2.4l head that is applicable.
thanks mike
mikes96neon is offline   Reply With Quote
Old 11-28-2005, 07:52 PM   #2
neon_rt
neon_rt's Avatar
neon_rt Normal reputation
Re: new head?
The valve cutouts in the pistons are in different locations sohc vs dohc. You may have problems in changing the heads because of valve to piston clearance. Also, the DOHC heads have more volume (cc's) in the head and your compression ratio will decrease if you don't change pistons too. You will need to use a Dohc intake and exhaust manifold. You may also have to change the computer because of the different torque curve produced by the Dohc setup. You could also consider installing a Sohc Magnum Head, that also comes with some expert level mods that you will need to do. Trade you neon for one with a Dohc in it, if you want a Dohc so bad.
neon_rt is offline   Reply With Quote
Old 11-29-2005, 08:38 AM   #3
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: new head?
Is there anything wrong with it? It will take some work to replace it with a DOHC as mentioned neon_rt and not worth the time and effort in my opinion. Better choice would be to replace your SOHC engine with a DOHC.
das2123 is offline   Reply With Quote
Old 12-01-2005, 01:02 PM   #4
wafrederick
Banned
wafrederick Has more negative feedback than positive
Replacing the sohc engine with a dohc engine is the cheaper way.You have a whole lot of work putting a dohc head on a sohc engine with lot of changes and would cost more than replacing the engine.You might have to use the computer and I have some bad news on Chrysler computers.Chrysler computers can be programed with the vin burned in once and the computer is done after that.The only choice on the computer if it does not work,a new one and and has to be programed and the vin burned in with Chrysler's factory scan tool,DRB III or a Vetronix scan tool.Those are the only scan tools that will program and burn in the vin on Chrysler computers.
wafrederick is offline   Reply With Quote
Old 12-01-2005, 01:30 PM   #5
das2123
das2123's Avatar
Re: new head?
Why would you have to do all that. Just get the DOHC from the same year as the engine and he would be fine. No need for reflashing or reprogramming. If he gets a 95 engine he would need a 95 PCM, 96 engine 96 pcm, 97-99 engine anyway pcm from 97-99 will do.
Old 12-02-2005, 08:21 AM   #6
wafrederick
Banned
The 2.0 and 2.4 computer are probally differant some way,call an auto salvage yard on that.Like I mentioned,a Chrysler computer can not be reprogammed.A Chrysler computer can be programmed once and they are done after that
Old 12-02-2005, 08:40 AM   #7
das2123
das2123's Avatar
Re: new head?
If you are swapping in a DOHC 2.4 engine from stratus then a 97-99 DOHC computer from a neon will work fine.
Old 12-03-2005, 06:00 AM   #8
maykelcj
maykelcj's Avatar
maykelcj Normal reputation
Re: new head?
I heard that the only neons with that problem are SRT4s.
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
maykelcj is offline   Reply With Quote
Old 12-07-2005, 12:26 AM   #9
NJH_Habitatpro
NJH_Habitatpro Normal reputation
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Re: new head?
You have to change like everything bro. It would be a pretty heffty chore.
NJH_Habitatpro is offline   Reply With Quote
Bookmarks
Google
Web AF
