Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 11-28-2005, 01:02 PM   #1
biketucson
biketucson Normal reputation
Send a message via MSN to biketucson
tranismisson oil cooler
anyone know how to install a transmission oil cooler on a 99 blazer. it seem like there is very little space infront of the AC coil and not enugh space infront of the fan
biketucson is offline   Reply With Quote
Old 11-28-2005, 02:37 PM   #2
wolfox
wolfox's Avatar
wolfox Normal reputation
Send a message via Yahoo to wolfox
Re: tranismisson oil cooler
Place it behind the radiator off to one side to aid in heating the transmission fluid in winter. Or, just place it in front of the A/C condensor off to one side to get maximum cooling. Look for a plate style cooler, they tend to offer much more cooling for much smaller packages. One as small at 7"h x 9"w x 1" thick would be optimal for a 4L60E that saw moderate towing loads.
wolfox is offline   Reply With Quote
Old 11-28-2005, 04:42 PM   #3
jsgold
jsgold Normal reputation
For the heck of it, look at the "better" coolers, which look like small radiators when checking these out. At the time Advance was out of them and I saw two "flat" models. Did not know there was another option until later. The smaller one was too small, the other fit my 93, but with a lot more effort than I thought it would. The other unit they were out of was more money but would have been easy to install and best unit as it was actually smaller in size although it was thicker. These come with adapters to connect to your existing cooler lines and are a nice thing to have.
I used to be indecisive, now I am not so sure.
jsgold is offline   Reply With Quote
Old 11-28-2005, 07:10 PM   #4
wolfox
wolfox's Avatar
Yep, that's what a plate cooler is. They look like mini, black Radiators. Look for the kit from Jeggs.
Old 11-28-2005, 07:18 PM   #5
jsgold
Wish I had bought that type for sure. The one I did buy does well, it is flatter and larger but required me to do some fitting for sure. The one I have looks like this
http://www.partsamerica.com/ProductD...number=242016&
parttype=895&ptset=A
This is what I will use if I start towing.
http://www.partsamerica.com/ProductD...pe=895&ptset=A
Old 11-28-2005, 07:27 PM   #6
wolfox
wolfox's Avatar
Any port in a storm! Reducing operating temps by as little as 20 degrees will extend transmission and fluid life like you would not believe. When you tow, a biger surface area in a smaller package like a plate cooler really shines. Some of them even come with flat motor fans to further boost cooling in slow moving conditions and can be set to run with a thermostat too. But to verify what you have and plan to do - yes on both. Any little bit helps. I am planning on a Jegg's kit come Spring/Summer. It's too dam cold to be putzing around with the truck these days, and no daylight after work. :P
Bookmarks
Google
Web AF
