Oil pressure on 99 JGCL
jahillia
11-28-2005, 10:35 AM
Ok, pulling into my garage last night, my oil pressure needle bottomed out and the "check gauges" light came on. As I revved the engine, the needle went back to between 30 and 40 lbs as normal. When driving down the road, however, it again started to bottom out. Is this a sign that the oil pump is going out or is it something like the oil sending unit failing?
Any help is appreciated....
Thanks,
mx52nv
11-30-2005, 03:27 AM
replace the sending unit first and post back. very easy to do.
jahillia
12-07-2005, 08:41 AM
I ended up taking it to the shop. It was the oil sending unit ( I had no idea where it was) He also said that it had an oil leak around the unit that caused it to short out. Battery died at the same time!
