Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 11-28-2005, 08:42 AM   #1
kjlj
kjlj Normal reputation
01 Impala fan only works on #5 setting, 1 thru 4 don't work...
Unfortunately I have had some water behind my firewall due to a clogged drain. This probably has loaded up and may be damaged the fan. Good news, the drain plug is no longer clogged. Bad news, my fan only works on #5. Any ideas? Possible fuse? May be it will work after drying out.?
Thanks.
Keith
kjlj is offline   Reply With Quote
Old 11-28-2005, 06:12 PM   #2
BNaylor
BNaylor's Avatar
BNaylor +50
Re: 01 Impala fan only works on #5 setting, 1 thru 4 don't work...
If you have a manual HVAC system, it's classic blower motor resistor. Water leaking in through bad cowling seal, etc. will drip down onto the blower motor, blower motor resistor and wiring. Positions 1 - 4 from the HVAC head unit feeds to the resistor matrix to vary the blower motor speed. In position 5 the resistor is bypassed and the blower motor is fed direct battery power via the HVAC HI speed relay so the blower itself is probably OK.
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 11-28-2005, 07:19 PM   #3
thermal izod
thermal izod Normal reputation
had the same thing in my 2000 last year...bnaylor3400 is 100% dead on
thermal izod is offline   Reply With Quote
Bookmarks
Google
Web AF
