4x4 switch has no lightsnit78 11-28-2005, 01:59 AM Hello everyone, I did a search and could not find anything on the following problem: I have a 95 slt 4x4 and the switch on the dash does not have any lights lighting up and it does not switch into 4 wheel drive. I have checked the fuses and replaced the switch. Any other suggestions: rlith 11-28-2005, 06:45 AM Probably your TCCM is blown. nit78 11-28-2005, 11:48 AM Probably your TCCM is blown. can you tell me where the tccm is located? rlith 11-28-2005, 02:32 PM can you tell me where the tccm is located? Up under the center of the dash... s1193919 12-01-2005, 08:22 AM When replacing the tccm do you have to reprogram or reset anything or does the new tccm simply plug in? rlith 12-01-2005, 10:56 AM When replacing the tccm do you have to reprogram or reset anything or does the new tccm simply plug in? Just plug it in... You should disconnect the battery while doing so though. Automotive Network, Inc., Copyright ©2012
