brake pedal pulsation abs 1990 fleetwoodHAWG 11-26-2005, 10:04 AM anyone know what may cause the brake pedal to pulsate when slowing once speed reaches 20 mph or less. Stopping is normal when above that speed. Once slowed to around 20, the pedal pulsates as if the abs is kicking in. Speed sensor, or maybe calipers not sliding properly? DFBonnett 11-26-2005, 03:18 PM Do you hear anything at the same time? Usually when the ABS activates it is audible. If there is no sound, I'd suspect out of true rotors. Have you had new tires put on lately? Have you checked the torque on the lug nuts? HAWG 11-28-2005, 07:28 AM no, it is not the rotors. it only does this below 20 mph. the pedal begins to pulsate like abs activation. I read a gm bulletin about this problem over the weekend. Said that possible cause is calipers not sliding freely due to rust in the bore for the pins. Need to replace rubber bushings, and hone out bore etc, worth a try. thanks dieselcaddy 12-05-2005, 09:23 AM no, it is not the rotors. it only does this below 20 mph. the pedal begins to pulsate like abs activation. I read a gm bulletin about this problem over the weekend. Said that possible cause is calipers not sliding freely due to rust in the bore for the pins. Need to replace rubber bushings, and hone out bore etc, worth a try. thanks My 93 did this and they even turned the rotors and it still pulsated at lower speeds slowing down. I replaced the rotors with new ones and that solved the problem on mine. Blaze Automotive Network, Inc., Copyright ©2012
