Hahn turbo kit
Google
Web AF
the_game_rock
11-25-2005, 10:16 PM
Super 16G turbo kit does anybody have this installed on there car or know anyone that does? do they include everything you need? easy install? with this kit what need to be done to my motor besides pistons and rods?
das2123
11-26-2005, 11:14 AM
Super 16G turbo kit does anybody have this installed on there car or know anyone that does? do they include everything you need? easy install? with this kit what need to be done to my motor besides pistons and rods?The one that Modern Performance is a complete kit with a black and white photo installation manual. Installation should take between 8-10 hours of work, depending on you. I use to have one on another neon and I know quire a few people who have and they absolutely love them. With the Stage 1 or 2, you don't need to do anything else to your engine. The stock internals can hold the 5-7psi of boost. I would go with the Stage 2 and get the intercooler also.
the_game_rock
11-26-2005, 08:38 PM
to acheive around 325 horsepower what would I need to do in the motor and how much boost would I need to run? does valve springs help much?
das2123
11-27-2005, 04:54 PM
to acheive around 325 horsepower what would I need to do in the motor and how much boost would I need to run? does valve springs help much?That is a lofty goal...keep in mind, HP is great but you will need torque also to move the car. I would say you would need all the internals, rods, pistons, upgraded lifters and springs, port and polished intake, bigger TB, UDP, bigger exhaust, race cams and adjustable cam gears at around 10-15psi of boost. If that doens't get you there, then add a 50-75 shot of nitrous.
the_game_rock
11-27-2005, 09:13 PM
Its a project I dont want to go half assed I would rather go all out. Im tired of people trash talking neons. How much boost would be safe to run on a motor with all you mentioned?
nimitz23ky
11-28-2005, 04:40 AM
i redid the entire engine. from the bottom up. took alot of money, but if you have a goal, it shouldn't matter. right now i am running 22psi, and a 35 shot of nos. detonation factors are a bit higher, but you just gotta use it to your best knowledge. i also have a race block and head installed, but it is a SOHC....but, in order to achieve all this, you gotta do some major internal work. change out everything. no simple 'walk in the park'. but, it can be done. just watch your boost levels though...
das2123
11-28-2005, 08:27 AM
Its a project I dont want to go half assed I would rather go all out. Im tired of people trash talking neons. How much boost would be safe to run on a motor with all you mentioned?If you want this car streetable, then I would say the most boost would be between 10-15psi. If you want all out drag, then 20+ and you should be good if you have all the internals upgraded. You might want to invest in some prothane motor mounts and some upgraded axles while you are at it.
the_game_rock
11-28-2005, 08:48 AM
I already got some inserts I got my car with a broken motor mount replaced and it broke that one.
the_game_rock
11-28-2005, 08:49 AM
what compression of pistons should I get?
das2123
11-28-2005, 09:15 AM
what compression of pistons should I get?I'd go with the JE Turbo pistons...DOHC 8.8:1...SOHC 9.2:1 Compression.
the_game_rock
11-28-2005, 09:16 AM
would my motor be able to handle it?
das2123
11-28-2005, 09:26 AM
would my motor be able to handle it?If built up, then yes.
the_game_rock
11-28-2005, 09:29 AM
what would I have to do to support the pistons?
das2123
11-28-2005, 09:50 AM
what would I have to do to support the pistons?Eagle rods. This is the same engine you want to turbo and get 325HP right?
the_game_rock
11-28-2005, 09:53 AM
yea I mean want else would I would have to do the motor to be able to use those high compression pistons?
das2123
11-28-2005, 09:58 AM
yea I mean want else would I would have to do the motor to be able to use those high compression pistons?Rod bearings, main bearings, piston rings and the eagle rods should do you good.
redchainsaw
03-10-2006, 08:56 PM
[i have a good friend that has a 97 sohc, he turboed it and he is running 36 pounds of boost, he runs 11.4. i will get what he has done to his car and get back to you. i just know that he has dumped bout 27g's in it, an srt4 would run like an mivi van compared to his car, and the thing is it looks totally stock. ill get pics also.
JSUsaxman
03-10-2006, 09:27 PM
What is the difference b/w the Big 16G and the Super 16G. Will they both work in a 1st gen Neon???? Thanks
das2123
03-10-2006, 09:55 PM
[i have a good friend that has a 97 sohc, he turboed it and he is running 36 pounds of boost, he runs 11.4.With that much boost, I doubt anything internal is stock. If so, just wait for the big boom!
an srt4 would run like an mivi van compared to his car, and the thing is it looks totally stock. ill get pics also.A stock SRT maybe but not some of the SRT's I have seen. But that is a good time regardless if it's SOHC or DOHC.
das2123
03-10-2006, 10:06 PM
What is the difference b/w the Big 16G and the Super 16G. Will they both work in a 1st gen Neon???? ThanksBig 16G has a HP max rating of 340-380 HP and the Super 16 has a max rating of 625 HP and about a $400 price in difference. Yes both can be used on the neon. Hahn uses the Super 16G on the kit for the neon.
Google
Web AF
