Squelling Noise?johnrobertirwin 11-25-2005, 04:42 PM My mazada 626 just had the AC/alternator drive belt changed and it has been making a squelling noise ever since. It will only squeal when i start then car and then after it starts to warm up it will stop. I have used belt dressing and tried to tighten or loosen it to make it stop but nothing is working. Any sugestions would be greatly apreciated. bmarsh1605 12-01-2005, 09:29 AM well this is most likely the a slipping belt. mine was the same way when i first replaced it. i tried the same stuff (different tensions) nothing worked. a week later everything was fine and the belt stop slipping all by itself johnrobertirwin 12-04-2005, 01:44 AM well this is most likely the a slipping belt. mine was the same way when i first replaced it. i tried the same stuff (different tensions) nothing worked. a week later everything was fine and the belt stop slipping all by itself Yea i wish that was the case...this has been going on for a good two months or so...any other sugestions? digitalpimpin88 07-17-2006, 06:27 PM i have a 93 626 and my car was sqeeking to. i just tightened up the tension bolt a little bit and problem stopped. i've had to do it again once but it works. Automotive Network, Inc., Copyright ©2012
