Alarm System in Civic SI '05allanc 11-24-2005, 08:33 PM We recently purchased a new 05 Honda Civic SI and there is some sort of alarm system installed. I checked the user manual as well as the others supplied with the car and I can not find any reference to it. The reason that I know that there is an alarm system is that the horn started blaring (sp) at about 3 am the other morning and it stopped when we pressed the remote key a couple of times. Does anyone know if this alarm is standard equipment on this model and simply missing from the manual? If so, where do I get additional info about it? Thank you in advance. BrodyP 11-24-2005, 09:46 PM If you just bought it and do not know what you have seeing the dealer would be best. Copytech99 11-24-2005, 09:51 PM Simple test lock with remote, then unlock and open passenger door with key. You will then know. allanc 11-25-2005, 10:11 AM Simple test lock with remote, then unlock and open passenger door with key. You will then know. I think I did not explain myself properly. I * know * that the car is equipped with an alarm. My question was is the alarm included in the base '05 SI model. Automotive Network, Inc., Copyright ©2012
