Big question!
Siggi-Caprice
11-23-2005, 04:05 PM
Can anyone tell me the torque ratings for my 1988 Caprice Classic Brougham LS, the engine is 305 with 4bbl quadrajet and its rated 170 hp.
Thank you!
silicon212
11-23-2005, 10:07 PM
250@2800
Siggi-Caprice
11-24-2005, 02:18 PM
thank you, on what rpm are this monster motor creating 170 hp?
silicon212
11-24-2005, 07:04 PM
Here you go. :)
GENERAL ENGINE SPECIFICATIONS Optional V-8
90-Degree, Overhead Valve V-8
Cast Iron Block and Head
Engine VIN Code - H
Engine No. Cyl. Displacement: 8, 305 Cu. In.
Liter - 5.0
Engine Mfg. - Chevrolet
Carburetor Type - 4Bbl
Net Horsepower @ rpm - 170@4400
Torque @ rpm (ft. lbs.)- 250@2800
Bore x Stroke (in.) - 3.74 x 3.48
Compression Ratio - 9.3:1
Oil Pressure @ 2000 rpm - 45
Five Main Bearings
Hydraulic Valve Lifters
Siggi-Caprice
11-24-2005, 07:25 PM
Thank you master :worshippy
Where do you find this information?
silicon212
11-24-2005, 09:49 PM
http://www.google.com
PeteA216
11-26-2005, 03:55 PM
Why is it that the '84 model carbureted 305 has less power than the '88 model carbureted 305? (84 is rated at 163 hp)
HLandin
11-26-2005, 08:01 PM
On big reason is the use of hydraulic roller lifters starting in 1987 and a boost in compression (atleast for the Caprice 9c1 350-cid). This bumped the HP on all motors (HP on Caprice 350 jumped 25HP to 180HP).
silicon212
11-26-2005, 10:19 PM
HLandin nails it. The '84 had an 8.5 c/r and the '88 a 9.3 c/r. Along with hydraulic roller lifters, which were good for a 5-hp boost alone.
