Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 11-22-2005, 04:53 PM   #1
tgreer9768
tgreer9768 Normal reputation
oxygen sensors?
What are normal readings for the O2 sensors on an Impala??? Or perhaps a better way t to ask the question.... how would you test the to determine if they are defective?
tgreer9768 is offline   Reply With Quote
Old 11-23-2005, 05:16 AM   #2
bigrod118
bigrod118's Avatar
bigrod118 Normal reputation
Send a message via AIM to bigrod118 Send a message via MSN to bigrod118 Send a message via Yahoo to bigrod118
Re: oxygen sensors?
well our cars are smart enough that all the information is feed into the computer and the car will throw a code when things to bad ie O2 sensors, cat, things like that.
what problem are you having
bigrod118 is offline   Reply With Quote
Old 11-28-2005, 08:43 AM   #3
tgreer9768
Re: Re: oxygen sensors?
car intermitantly will die out while driving. Car will be running running fine at a constant speen but all of a sudden the rpms will either jump up high or most of the time drop drasticly. For lack of better wording... the engine will then seem steady out again but sometimes will show a check engine light after the rpms go up or down. Also when this happens when the car hits around 35-38 miles an hours you can hear the engine knocking really bad and there is almost no acceleraction. The knock clears up once the car gets up to about 45-50 mph.
I guess once the car goes through a couple driving cycles the problems goes away for a while... then is will do what i described above.... rise and repeat.
We just had the cat replaced last week for this problem... did not fix it. When we take it to the dealer (4 times) they never can tell us what is wrong with the car. The only code showing up is a crank sensor which they say checks out fine and there some engine knock code.
Old 11-28-2005, 10:11 AM   #4
BNaylor
BNaylor's Avatar
BNaylor +50
Re: Re: Re: oxygen sensors?
Which engine do you have - Series II 3800 or 3.4L?
The knock sensor module in the PCM is detecting knock because your crankshaft position sensor (CKPS - one at haramonic balancer) is going South and the timing is being thrown off. The dealer has not properly tested the CKPS because they probably ran it on a Tech II without duplicating your conditions. The only way to properly check the 18X (3800) or 24X (3.4L) pulses is with an ocilloscope. I'd trust the PCM which did throw a CKPS DTC error code. Post the specific odb-ii code if you can.
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 11-30-2005, 10:23 AM   #5
tgreer9768
Angry Re: Re: Re: Re: oxygen sensors?
its has the 3800... I got a chance to get the codes from the car...
p0336 - crank senosr code.... also said something bout 18x
car died out while driving home 3 times yesterday....
Old 11-30-2005, 10:29 AM   #6
BNaylor
BNaylor's Avatar
BNaylor +50
Re: Re: Re: Re: Re: oxygen sensors?
The CKPS is a common problem on the Series II 3800. Change it out and you'll be back on the road safely. Here's a procedure that will work although it is for a Grand Prix. The sensor cost ranges from $30 - $50. Good luck!
http://mykidz.net/GTP/CrankPosSensor.shtml
Timeslip 08/12/06
Bookmarks
Google
Web AF
