89 Chevy Suburbanspenn 11-21-2005, 11:09 PM My 89 Chevy suburban will not start. I do not have spark at the plugs. I have spark from the coil. I need help! 97cavalier 11-21-2005, 11:15 PM My 89 Chevy suburban will not start. I do not have spark at the plugs. I have spark from the coil. I need help! try getting new spark plug wires. broughy84 11-22-2005, 03:27 PM NO, I would say that the electronic ignition module inside the distributor cap is bad. Parts stores can test these, it's worth a shot. 2000CAYukon 11-22-2005, 04:50 PM My 89 Chevy suburban will not start. I do not have spark at the plugs. I have spark from the coil. I need help! If you have spark at the coil but not the wires, then the rotor and/or cap is bad. //2000CAYukon spenn 11-28-2005, 02:39 PM If you have spark at the coil but not the wires, then the rotor and/or cap is bad. //2000CAYukon I've replaced the cap but it did not help. I bought a coil to replace the oild one but have not installed it yet. If it works/or not, I'll let you know. Thank you for your help. BlenderWizard 11-28-2005, 03:17 PM My money's on the coil; I had an old Celebrity that did the same thing 1963chevypudriver 12-21-2005, 10:39 PM pull your distributer making note of its placement and have your local parts store test it to check the pickup coil. also it couldent hurt to change plugs wires and cap/rotor Automotive Network, Inc., Copyright ©2012
