Fuel Leak
Mitch_2005
11-21-2005, 08:26 PM
My 1995 neon is leaking fuel at the metal lines. I was wondering if there is a temporary fix I could do because I cant take it to the shop for a few days... Also, how much could new fuel lines cost?
Mitch_2005
11-21-2005, 09:44 PM
Would it be possible to put in rubber lines instead of the metal ones? Would this change the fuel pressure?
das2123
11-22-2005, 04:25 PM
My 1995 neon is leaking fuel at the metal lines. I was wondering if there is a temporary fix I could do because I cant take it to the shop for a few days... Also, how much could new fuel lines cost?I don't know of any temp fixes, but you could try something like JB weld or something similiar. As far as cost, try a junkyard, pull the lines you need and swap them in. Much cheaper route.
Would it be possible to put in rubber lines instead of the metal ones? Would this change the fuel pressure?You don't want rubber lines for fuel. The rubber will swell and crack. Better to stick with the OEM.
