93 s15 Jimmy 4wd
truck93
11-20-2005, 11:50 AM
I can't get my 4wd to engage. It is a push button. It will only try if I am in revearse, and it takes quite a few trys to get it to work (if it even works). Sometimes both Hi and Lo light up, and it isn't in 4wd. In any other gear, it doesn't even try. Wondering if it is the actuator. And if so, where is it?
mike01166
11-24-2005, 07:37 PM
had same problem
check vaccum lines, mine were broken
truck93
11-24-2005, 08:01 PM
had same problem
I checked them. Found a hole in line going into the vacuum actuator under the battery. Replaced it and it worked fine until I started my truck later that day. It is doing the same thing.
mike01166
11-24-2005, 11:10 PM
my neighbor fixed mine, and I watched him, but really cant explain it. I will ask him next time I see him
blazes9395
11-25-2005, 02:14 PM
Sounds like the encoder motor is going. Try unhooking the battery and letting it sit for a few minutes, reconnect and see what happens.
truck93
11-25-2005, 03:20 PM
Thanks Blazes. Good idea. I have been reading more on it. I checked the wires going to the encoder motor and they are ok. Unhooked the battery and I am going to let it sit for a while and try it later on.
truck93
11-25-2005, 07:10 PM
Blazes, it worked. After unpluging the battery for a while it works. Don't know how long it will last. I suppose I will have to change it. Thanks a lot. I was getting frustrated. I appreciate the help.
blazes9395
11-25-2005, 11:44 PM
Glad to have helped, but its probably short lived, and almost time to change the encoder motor.
