oil in the cooling systemzonkone 11-19-2005, 12:15 PM need help (88 mx-6 turbo, standard)... recently changed the head gasket, water pump and thermostat. also drained the coolant numerous times, but the oil is still mixing with the coolant but no evidence of water in the engine... zonkone 11-19-2005, 12:17 PM looking for a lowering kit for a 88 mx-6 turbo. 96probegt 11-23-2005, 11:29 AM try back flushing the cooling system the heater cor and all that MazdaX 11-29-2005, 04:04 AM Take it in and have the cooling system flushed with a cleaner and see if you get oil later down the road still mixing. Also, just to make sure you have no leaks in Head/Intake Manifold gaskets, Pull off your oil filler cap and look inside it for white goo, if none you should be fine in that department. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
