Teg stalls immediately after it startsMVoigt 11-18-2005, 09:07 PM It is getting alot colder here 30-40 degrees. and my car is now doing this thing where I turn the key and it fires up but only for less than a second and then it immediately stalls. This will continue for a few times. Usually by about the time I start yelling profanity at it. Then I can get it to start which leads me to believe either (a) It is demon possesed and needs its fix of profanity, (b) the fact that after a few unsuccessful starting attempts, I lightly press the gas and a few attempts later, it starts, (c) my actions mean nothing and this is an ignition related problem that fixes itself intermitantly, or (d) I am totally lost. Plugs and wires are new, cap and rotor is ordered. Intake resonator was removed when I actually cared about getting a slight performance improvement and mean growl, so intake air is very cold, but no colder than a usual cold start. This is my $900 work beater, so it must start reliably. tbizzle1 12-05-2005, 12:22 PM try changing your main fuel relay (MFR). my 91 teg does the same thing...seems to start up but immediately dies, no matter how much you pat the gas. if i wait about 5 minutes, it starts ok. haven't gotten around to changing mine though. the part's around $60 at your local honda dealership. get an auto manual (haynes, etc.) for your teg & change it yourself to save some $$$. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
