Problem with 93 Cadillac Deville
SnipesXxX
11-18-2005, 03:57 PM
My bro had a 93 Cadillac Deville with I think a 4.9 in it and for some reason if he drives it more than say 30-40 miles it dies and won't start back unless you let it set. Sometimes you can let it set for 15mins sometimes 2 hours. All lights come on but it just won't crank. He said sometimes before it does it, you can be driving and it acts like it ain't getting any gas. That makes it sound like a fuel issue but doesn't explain why the car won't crank once it has died.
Any ideas?
BTW if you think it's a sensor causing the problem could you give me a idea on where it's at and what it's called?
Thx all
caddydaddy
11-22-2005, 10:16 AM
Your best bet would be to check for any set computer codes.
Check here for how to check them:
http://myweb.accessus.net/~090/dtcobd1.html
SnipesXxX
11-24-2005, 02:57 PM
do I have to buy the tester or is it built into the caddy? Or does it show up on the little AC/heat display?
caddydaddy
11-25-2005, 11:04 AM
No, it's built into the car. Just follow the instructions on that link.
SnipesXxX
11-25-2005, 11:47 PM
didn't know that. I'll give it a try once I see my bro again. Thx alot
BTW does the error codes(if any) show up on the heat/AC display?
HAWG
11-26-2005, 10:13 AM
check the module in the distributor. when they are bad they will cause that problem.
DFBonnett
11-26-2005, 03:12 PM
All lights come on but it just won't crank. ..... won't crank once it has died.
Do you mean it won't crank over or it won't fire up?
If it won't crank over, you might want to check the condition of the battery cables and connections and examine the insulation for signs of swelling underneath.
If it dies and won't fire up until it cools a bit, suspect the ignition module as Hawg noted.
When it dies, does it seem the longer it's been running the longer the wait for restart? Again, suspect the module.
SnipesXxX
11-26-2005, 06:19 PM
He done changed the ignition module I think with no luck. When it dies it acts like the battery is dead and won't crank the engine yet all the lights and stuff still work. Just won't crank to get the chance to fire up.
DFBonnett
11-27-2005, 08:52 AM
Check the battery cables, especially the positive. for internal corrosion.
diddy0071
02-13-2008, 10:47 PM
Does anyone know if the ODB I testing works on a 92? I have a 92 and I want to see if I can check for trouble codes using the method above.
caddydaddy
02-14-2008, 06:43 AM
Yes. The OBD 1 I think started in the late 80's.
maxwedge
02-14-2008, 03:07 PM
Correct, but engine codes and info can be accessed thru the a/c control head, check caddyinfo.com for the how to. This thread is way too old and will now be closed.
