98 Malibu Whining, HELP?
rdhl
11-18-2005, 09:51 AM
I have just recently replaced the power steering pump twice, 4 alternators, 2 new idler pulleys, a new tensioner pulley, new water pump, new platinum spark plugs and gapped, all new coolants including the power steering fluid, and i have a whine thats RPM related !! I cant replace anything else, theres nothing left to repalce, all items are OEM and torqued to the manual specs. It still sounds like an alterantor whine but i cant believe 4 in a row are bad, any suggestions out there? Its really loud at 1700 to 2500 RPM and goes up and down with the RPM range, very annoying. When i put a tuning device on the alternator bracket and or alternator , thats where the sound comes from, Is there possibly something that can make an alternator whine other than the alternator itself being bad?
bcopeland
11-18-2005, 07:45 PM
Maybe its not the alternator and it is the belt tensioner.
rdhl
11-21-2005, 10:10 AM
replaced that as well!
maxwedge
11-21-2005, 11:53 AM
Is the noise gone with the belt off?
rdhl
11-21-2005, 03:35 PM
I did not know you could do that, will that hurt the car?
maxwedge
11-21-2005, 07:50 PM
No, get the belt off and run it for a few minutes see if the noise is gone.
rdhl
11-22-2005, 09:27 AM
I will try that this weekend.
goofy4467
11-22-2005, 09:20 PM
Check the air conditioning pump clutch, if it does not release all the way it will whine its metal on metal, with the car at idle and the ac off the end plate on the clutch will not be turning if its off.
When they drag it will turn slowly.
OR the bearing in the clutch is dry and squealing.
Take the belt off and turn it by hand
rdhl
11-23-2005, 09:07 AM
Ok Thanks i will check that as well,
cavicchia
01-08-2006, 02:31 PM
What did you ever find out about this I have the same symptoms and have already did everything you just described.
Thanks
sswpriz
01-08-2006, 03:33 PM
I had a whining noise that I posted about also here a month or so ago. Well, on Friday, is sounded like every bearing under the hood was going bad !!!! I started the car up on Sunday nad all was quiet for about the first 3 minutes, then it started again. Definitley metal grinding, and after carefully listening with the long screwdriver place against a few pieces it sure does sound like the bearings in the power steering pump are shot. I will let you know what my mechanic says after he fixes it !!!
sswpriz
01-12-2006, 01:32 PM
Mechanic replaced the bad water pump and serpintine belt....no more whinging noise. This must have been going bad for quite a while !!!
