Misfire problemssganc4life_4 11-17-2005, 01:52 PM Well, i just changed the plugs and wires and gapped em correctly. Im misfiring once I hit around 15 psi at about 5k rpms, Im thinking its a distributer or coil pack. Anyone else having the same problem or had the same problem. Also, if I push the gas to like 10psi, I have no problems in any gear. sganc4life_4 11-18-2005, 08:45 AM no1 has any ideas? -Josh- 11-18-2005, 09:38 AM Have you run a balance test to determine which cylinder? Carolina Z 11-18-2005, 12:33 PM What brand of plugs are you using, had the same problem at one time due to the plugs that were being used. However I would think that it would show up before the RPM's that your indicating. sganc4life_4 11-19-2005, 12:33 AM Well, I had to drive to FL today, so nothing yet...using iridium plugs and same deal but with a better idle. How do I do that test? sganc4life_4 11-20-2005, 11:10 PM hey, thanks for all the help and wonderful responses crunchymilk55 11-20-2005, 11:54 PM Buy NGK 6's gapped at .028, then make sure the wires aren't eroding ez1286 11-21-2005, 12:10 AM It's because you have iridium plugs. My brother had the same thing about a year ago. Switch to oem plugs and it will go away. We didn't believe it either but that what the problem was it kinda feels like the car shutters at higher speeds right? soyee7 11-21-2005, 01:42 AM buy NGK BPR7ES plugs and gap them at 26, this will fix it. Then if it is still persistant you should look at your plug wires and make sure there are no holes around the bottom of them, if there are you need new wires. 90% of the time its not the coil packs. sganc4life_4 11-21-2005, 12:22 PM Thanks, ill go out today and get plugs. sganc4life_4 11-21-2005, 12:31 PM I gave my mechanic a call and he said it might be the TPS or a camchaft sensor, does this sound right? Also I found out after like 5500 rpms its fine, no bogging or misfiring. soyee7 11-21-2005, 02:06 PM your mechanic could be correct, but it is most likely an ignition problem. Make sure the wires are put on in the correct order, its usually the smallest and cheapest thing that ends up being the problem. Let me know it the plugs fix it, they should only be about 8 dollars from your local NAPA. sganc4life_4 11-21-2005, 06:33 PM Plugs I put in I gapped correctly, still the same problem...checked all the wires and their fine, im putting in a new TPS tomorrow to see if it fixes the problem. Automotive Network, Inc., Copyright ©2012
