Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 11-16-2005, 09:15 AM   #1
mikebar4
mikebar4 Normal reputation
Question 2003 z71 fuel pump noise
my fuel pump in my 03 z71 with the 5.3 makes an awful noise. it has done this since i had it, about 4k miles. the truck has 35k on it. i never asked the previous owner about it and have lost in touch with him. the truck runs fine but the noise is pretty loud and people always asks me about it. do i need to change my fuel filter? any ideas???????
oh yeah,,,i average around 14.5 mpg with a set of 285s on it.
mikebar4 is offline   Reply With Quote
Old 11-16-2005, 10:14 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 2003 z71 fuel pump noise
Start with a fuel filter.
Also a good fuel pressure check may be in order.
MT
MT-2500 is offline   Reply With Quote
Old 11-16-2005, 02:31 PM   #3
mikebar4
Re: Re: 2003 z71 fuel pump noise
just put in new fule filter and still makes the same noise. any other ideas?
Old 11-16-2005, 02:37 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Move on to the fuel presure test.
Any hard starting?
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
Post back fuel pressure readings.
Old 11-16-2005, 09:27 PM   #5
97cavalier
97cavalier's Avatar
97cavalier Normal reputation
Any hard starting?
Is it like a ring noise? because i have a 99 silverado with the 4.8 and it has a anoying ring and it is the fuel pump. I am going to replace it nd the sending unit soon.
97cavalier is offline   Reply With Quote
Old 11-17-2005, 09:25 AM   #6
mikebar4
Re: Re: Re: 2003 z71 fuel pump noise
its like a wining noise. cant quit figure it out and i dont have the tools to do the pressure test. might have to take it to a mechanics shop before its over with.
Old 11-18-2005, 06:02 PM   #7
97cavalier
97cavalier's Avatar
Re: Re: Re: Re: 2003 z71 fuel pump noise
ya, mine does the same thing, it has been doing it since about 30,000 and i now have 100,000 on it and still doing it. I know it is the fuel pump, but just don't have the time to replace it. I am going to do it soon though. It is not that hard you just losen the straps on the tank and reach in there and pull it out.
Old 11-19-2005, 11:57 AM   #8
tykrz
tykrz's Avatar
tykrz Normal reputation
If it's noisy,it's trying to tell you something...like its on the way out. It may last a very long time or it may crater next drive down the street. I find these things always seem to crater out at the most inconvienient time, such as in the middle of nowhere. I'd change it out before you have a huge tow bill to add to the repair.
tykrz is offline   Reply With Quote
Bookmarks
Google
Web AF
