Why won't my QX4 stay idling while cleaning throttle body?meyersk76 11-13-2005, 03:54 PM Did just fine on my 300ZX, but the QX4 just dies instantly. Am I retarded or is ithis just the way it is with the Infiniti's? lewisnc100 11-14-2005, 07:28 AM Clean it with throttle body cleaner while the engine is off. Or is it not idling correctly after you cleaned it? nissan_240sx 11-16-2005, 03:02 AM Actually you can clean TB's while the engine is on. You're supposed to spray little at a time, maybe you flooded the TB? or maybe it is the infinitis... LOL lewisnc100 11-16-2005, 07:54 AM Probably could, but I wouldn't want that gunk going through my engine. Even though its loosened with the solvent its still pretty much a tar consistency when you clean it and it will stick on the way through. OP, buy a bottle of throttle body cleaner which is made for this and follow the directions on the can. It also usually requires some brushing with a soft toothbrush as well on both sides of the throttle plate. Automotive Network, Inc., Copyright ©2012
